How can I run an extenal script
How can I run an extenal script?
I have the need t run a csh or perl script
all these lines do nothing:
Do {Exec sh -c "/nfs/iil/home/yoavk/Scripts/vnc/FvwmThemes/CshTestScript"}
Do {Exec /nfs/iil/home/yoavk/Scripts/vnc/FvwmThemes/CshTestScript}
Do "Exec  /nfs/iil/home/yoavk/Scripts/vnc/FvwmThemes/CshTestScript"
thanks
Yoav Koren
The second one ought to work. The sript is executable I presume? Also, have a look at ~/.xsession-errors if Fvwm logs to that file, it might tell more as to what exactly is wrong.
Thanks
the second one doesnt work
did you succeed to do that? can you post such a line that works?
p.s I don’t have a file ~/.xsession-errors, where else can ir be?
thanks again
Yoav Koren
This one is from FvwmMpd:
Do {Exec mpc play } (GetValue 1) { >/dev/null}
hello
I have found the solution
Set $Perl = {/usr/intel/bin/perl} Set $DIR = {/nfs/iil/home/yoavk/Scripts/vnc/FvwmThemes} Do {Exec }$Perl{ -w }$DIR{/PerlTestScript &}
you can look at [color=red]FvwmScript-ComExample[/color]
thanks
Yoav Koren
