hello
I have a need to get the $FVWM_USERID
How can I do that?
I thought you could just reference it like ${FVWM_USEDIR} , if that doesn’t work you can get it using something like
(GetOutput echo $FVWM_USERDIR 1 -1)
Tanks
it still doesn’t work
WriteToFile /nfs/iil/home/yoavk/Scripts/vnc/FvwmThemes/OutFile ${FVWM_USERID}
will write to the file {FVWM_USERID}
WriteToFile /nfs/iil/home/yoavk/Scripts/vnc/FvwmThemes/OutFile $FVWM_USERID
will write nothinf to the file, because it is an emty variable
Set $UserId = (GetOutput echo $FVWM_USERID 1 -1)
will make an error at the vnc log
[color=blue]Line 73: parse error[/color]
any other suggestions?
thanks again
Write it like this:
Set $UserId = (GetOutput {echo $FVWM_USERID} 1 -1)
thanks
this one works
Yoav
