How do I make fvwmscript Menu get values past 9? It always crashes when I try to add the {10}
For exemple:
Widget 20
Type Menu
If (GetValue 20) == {1} Then
If (GetValue 20) == {2} Then
And then, when I add the {10}, it breaks and won’t open anymore.
If (GetValue 20) == {10} Then
Can someone help me?
