I am using only one desk which I am showing in FvwmPager, which is in turn swallowed in a FvwmButtons. Currently the FvwmPager shows the desktop name. I can change then using the DesktopName command and I can also put it on top or bottom using the *FvwmPager: LabelsAbove and *FvwmPager: LabelsBelow commands respectively. However I want to hide it altogether. Is there a way to do this?
As a side question, is there currently a way to put separators between the buttons of FvwmButtons?
I am using fvwm 2.6.3.
Thanks a lot in advance.
