Thank you, Thomas. I found your tip with the “search” feature and found it very useful.
Do you know if it’s possible to make a window unhide when a key is pressed and hide when the same key is not pressed?
Let me clarify:
This is the right-bottom corner of my screen:
Now I put this code in my .fvwm2rc:
[code]Key Alt_L A C Function hidebuttons
AddToFunc hidebuttons
I All (CurrentDesk, !Transient) ThisWindow (“FvwmPager”) WindowShade SE
I All (CurrentDesk, !Transient) ThisWindow (“FvwmWinList”) WindowShade SE
And when I press Ctrl+Alt the FvwmPager and the FvwmWinList show up:
Pressing the same key again, they disappear, and so on.
Is there a way to make them show up when Ctrl+Alt are pressed and disappear when Ctrl+Alt are not pressed?
Thanks.
Franco1 (from Rome)
P.S.: Compliments to the developers of Fvwm. For me it’s one of the three killer applications of Linux.
If you mean so that it works when the keys are held down, and then hides when they are released, then no. This was tried for a while, but it was too iffy, and didn’t work. They “KeyUp” / “KeyDown” reaction times are no longer in FVWM.
That said, assuming you’re after a certain delay, you might find the following useful:
