I am back to using fvwm2 after some time of using Gnome. I like configurability of FVWM2.
However, there are a few things that I want to resolve:
How can I “lock screen” such that I kind of go back to GDM and use “Switch User” functionality. (that is, I lock the screen, then can select “switch user”, and log on as another user, and then later I can do the same and switch back to my session).
How to make Nautilus root window to pop up the FVWM menu when clicked?
Can fvwm2 support persistent sessions (not exactly a most important requirement, but useful)
Applications that draw over the root window (Nautilus, kdesktop, etc.) can have their bindings overridden by FVWM via the context of the binding. That binding is ‘D’ for desktop a la:
Yuo might also want to look at the gdmflexiserver command, And possible xscreensaver >=4.21, with support for gdmflexiserver compiled in (But gnome-screensaves seems to have the same interface. It’s only a suspicion (i.e. I’ve not googled it), but I believe it might be a repackaging of xscreensaver with other binary names)
I have recently changed from kdm to xdm. I have learned (thanks to Pixelbrei) that fvwm can be used in the xdm login screen. Wonderful!
This is the screenshot of my xdm login screen. Basically, there is a FvwmButtons that swallows xdm login and has some buttons to reboot and start/stop ethernet card.
As a [minimal] advantage, I get my screen prepared in the login. When fvwm starts I already have the background image, root-tail and conky already running. If I switch the computer on, I can follow what is going on without logging in. Not very spectacular, but I am glad fvwm has help me in producing a nice login screen.
P.S.: Should this thread be reframed? How to make Gnome and GDM work with FVWM?
I just followed this article on the gentoo wiki. It suggests to create a /etc/X11/xdm/Xsetup_my with the applications you would like to have in your login screen. This is mine:
sleep 15 && import -w root /tmp/xdm.jpg &[/code]
And you have to kill fvwm (that is running as root) when you leave xdm. I have these in /etc/X11/xdm/GiveConsole_my
[code]killall xmessage
killall fvwm
killall xclock
killall xterm
chown $USER /dev/console[/code]
You have to place your fvwm configuration inside your root user (/root/.fvwm) or provide a config file.
Amazing all the things you can do on your login screen
