i want to know how to setup application menu, e.g. firefox or gedit, in fvwm window manager,thanks.
I want to know whether you can re-explain that, and tell us what it is you want to do.
Sorry, i just want to know how to setup the font style of application menu.
Assuming you’re referring to a menu in the program, then this isn’t under FVWM’s control whatsoever – that’s the job of the widget set the application uses.
You want to google for ‘gtk theming’ and optionally look at the gtk-theme-switch2 program.
Yes, My menu font in the program is too large, and how to change the menu font size, can you tell me how to do?
hi
Look at a program named “gtk-chtheme”.
It’s a tool to do what you want.
gtk-chtheme tools is not found in my system, my system is gentoo
ryo@Gentoo ~ $ eix gtk-chtheme
* x11-themes/gtk-chtheme
Available versions: 0.3.1
Installed: 0.3.1
Homepage: http://plasmasturm.org/programs/gtk-chtheme/
Description: GTK-2.0 Theme Switcher
thanks, my problem have be solved. and whether have a tool can setup the tool bar style, example, only icon or text and icon
liwenqiu:
ryo-san:
hi
It’s a tool to do what you want.ryo@Gentoo ~ $ eix gtk-chtheme * x11-themes/gtk-chtheme Available versions: 0.3.1 Installed: 0.3.1 Homepage: http://plasmasturm.org/programs/gtk-chtheme/ Description: GTK-2.0 Theme Switcher
