How to use QT.SetWindowOpacity in fvwm?
I want use Qt to change the window opacity. the Documents in QT said setWindowOpacity function on X11 need composite manager and specific _NET_WM_WINDOW_OPACITY atom supported by the wm.
Note : On X11 you need to have a composite manager running,
and the X11 specific _NET_WM_WINDOW_OPACITY atom needs to be supported by the window manager
you are using.
I use xcompmgr as the compositor, but don’t know if the fvwm supported the specific _NET_WM_WINDOW_OPACITY atom.
I can’t change the opacity of window, is it a problem with compositor or not supporting the specific _NET_WM_WINDOW_OPACITY atom ? and How do I know which window manager supports the specific _NET_WM_WINDOW_OPACITY atom?
thanks a lot!
I used picom insteading xcompmgr, and the opacity of window can be changed.
The picom sample file has many configuration options. It is good to start with this:
/usr/share/doc/picom/examples/picom.sample.conf
thanks, theSetWindowOpacity works well under the picom.
