As u can see I use stonecrast greenv2 config and Opera 9.
as u can see the widget Touchthesky has a decoration.
Is there a way to toggle decorations to all opera widgets?
Thank u.
P.S.: this question is both here and Greenv2 config Thread.
Vieri
Ascertain the widget’s properties via FvwmIdent or xprop(1) and do the same for Opera. If this “touch the sky” widget is indeed a child window of Opera, the class or at least the resource ought to be the same, hence you could match on that:
Style whatever !Title, !Borders, BorderWidth 0, HandleWidth 0
And read this:
linuxgazette.net/127/adam.html
Well, WHY did you do that? Someone was going to answer you anyway – you didn’t need to post it twice, since doing so has some problems with it:
- It makes searching via these forums a pain.
- It means replies to the SAME piece of information become disparate.
- It annoys the hell out of moderators/administrators (ahem) who then have to clear up the mess.
Not to mention your question ought to really have been in Basic Questions, hence I am moving it there, and removing your post from the Screenshots and Configs forum.
Thank u.
You are right. I thought that Stonecrest could give me a different answer.
BTW, thank u.
Vieri
