icefvwm, with theme manager (decor)
The idea is that users create their own decor (themes) for sharing.
Just drop your theme into /home/username/.fvwm/themes and it’s “installed” ! (easy like in icewm)
The theme selector is here : patrick295767.pa.funpic.org/them … lector.jpg
To load the theme (after seek & click), just select in this menu “load theme”
Here is the screenshot: patrick295767.pa.funpic.org/them … cefvwm.jpg
(shoot 2, with rounded corners and fluxbox appearance: patrick295767.pa.funpic.org/them … orners.jpg )
tar.gz of the config : patrick295767.pa.funpic.org/them … ger.tar.gz
The features:
- click to focus windows
- decor (fvwm theming)
- icewm feelings (note that the taskbar are replaced by moveable & resizeable dockers !!)
- as fluxbox, edgeresistance 0, only when dragging the windows
- save/restore windows previous position of your windows (saved when you close them) - alt f1-f6 to go to the workspaces
- windows key for edgeresistance = 0 (then it returns to edge resistance 1) (like in pekwm !) - windows key, for displaying the fvwmdocker as top layer (time, icon manager, …) then it returns to bottom layer (after few sec.)
- window menu (saveposition, fullmax., toggle title, … )
- window while moving windows, display the fvwm pager on top layer to know where you are going … - alt + mouse right / alt + mouse left for resizing and moving respectively (fluxbox feelings
- double click title bar to maximize and unmaximize
- something as icewm : going to next/adjacent workspace , gives you focus of your last previous application (important point for appreciating the use of workspaces)
Howto:
just replace the .fvwm folder into /home/username/
so that you have /home/username/.fvwm
Please do not hesitate to create your own decor and share it !!
- place your decor in .fvwm/themes/
a/ as single .decor file
b/ or as a file.decor + its foldernamefyourdecor (do not folder to set the setenv)
an example of how it work, I would suggest to edit the /home/username/.fvwm/themes/patxp.decor
Enjoy !
__
Great thanks to all fvwm & thomas !
(mod of configs from this forum)
