Hi everybody
I defined in my config some specific icons i.e. for firefox to override the one used by default!
This is working only the firt time I iconify an app: if I start firefox, iconify it, I have the icon I defined, I deiconify it and iconify it again and now I have the default firefox-icon!!!
If I stop it and restart it I have the described behavior again!
What can I do to fix that???
I think there is an interaction with the gnome-settings-daemon (definitively creating problems) but I do not know how to bypass it and I need it for the gnome related apps!
Best regards, Brice
ps: fvwm 2.5.12 and gnome 2.10 (ubuntu hoary… I’ll be soon back under debian testing! )
Maybe you need to use this:
Style firefox EWMHMiniIconOverride, MiniIcon <someicon>
No I replace also the mini-icon (used on the thumbnails) but now I want to replace the normal icon!
Here is what I have in my config file :
Style * EWMHMiniIconOverride, IconOverride
Regards, Brice
Hi
I solved this problem!! It came from the DeThumbnail function which is bound to deiconify in FvwmEvent!
In fact, you have to add at the end of this function + I DestroyWindowStyle
otherwise you’ll get the described problem when doing a normal iconifying.
For completeness, the full code is:
[code]DestroyFunc Thumbnail
AddToFunc Thumbnail
- I Raise
- I ThisWindow (!Shaded, Iconifiable, !Iconic) PipeRead
“/$[fvwm_scripts]/thumb $[w.id] $[fvwm_icon_size] /dev/shm/icon.tmp.$[w.id].png;
echo WindowStyle IconOverride, Icon /dev/shm/icon.tmp.$[w.id].png”
- I TestRc (Match) Test (f $[w.miniiconfile], f /dev/shm/icon.tmp.$[w.id].png) PipeRead
“composite -geometry +2+4 $[w.miniiconfile] /dev/shm/icon.tmp.$[w.id].png
/dev/shm/icon.tmp.$[w.id].png; echo Nop”
- I Iconify
DestroyFunc DeThumbnail
AddToFunc DeThumbnail
- I PipeRead “echo Test \(i \$\[Icon-$[w.id]\]\) WindowStyle Icon \$\[Icon-$[w.id]\]”
- I TestRc (NoMatch) WindowStyle NoIconOverride, Icon
- I Exec rm -f /dev/shm/icon.tmp.$[w.id].png
- I All (Iconic, CurrentPage) PlaceAgain icon
- I DestroyWindowStyle
the thumb command can be found here: http://fvwm.lair.be/viewtopic.php?t=190
Of course bind DeThumbnail to deiconify in FVWMEvent.
For those using the (De)Thumbnail function of Taviso or Pem (sorry guys!) I would advice you to modify them, also the part with SetEnv seems to be facultative.
Regards
Brice
PS: I directly found the solution in the FVWM FAQ…
