It looks cryptic, but it just describes how the menu items are to be layed
out. In the above example:
“%.4s” – places a side picture (plus four pixels gap)
“%.1|” – begins the hilighted area of the menu (the select part of it).
“%.5i” – inserts the first miniicon (plus five pixels gap)
“%.5l” – first column left aligned
“%.5l” – second column left aligned.
“%.5r” – third column right aligned.
“%.5i” – second miniicon (plus five pixels)
“%2.3>” – two pixel gap, plus sub-menu triangle, plus three pixels.
“%1|” – one pixel, plus end of hilighted area.
I suppose what makes it harder is the fact that you can position these things
with pixel offsets. What the ItemFormat I defined does, is simply placed the
miniicon to the right. Everything else is the same as per the FVWM default
ItemFormat.
because the menu font has a body of 12… but when wallpaper browser pops up it is too big because of the name of files… so i need to make the body of the font about 8
