I’m still new, still messing around. I’m wondering how to see exactly what my currently active configuration is. For example, locally, our main configuration is system.fvwm2rc. It contains this function augmentation: [code]AddToFunc MoveOrRaise
- C Raise
- M Raise
- M Move
- D Lower
[/code] with no corresponding DestroyFunc command, so it’s possible there are some other actions in that function. In addition, I don’t see a Mouse 1 command tied to that function. It’s either already bound by default, or I’m barking up the wrong tree thinking that modifications to that function will have any effect.
So, I would like to dump the currently active configuration. In my menu hierarchy, I sawFVWM2 Menu->Modules (Advanced Users Only)->Config
Being a novice user, I naturally ignored the warning and selected it. Nothing happened that I could tell. I then tried “man -k Fvwm”. I saw lots of other Fvwm* commands, but not FvwmConfig. Google search for “FvwmConfig” also turned up nothing. I did find fvwm-config, but it seems to mostly be a helper program to run within your config file.
So, is there a way to dump the currently active configuration?
Thx…
