I want to make a simple toggle function, something like this:
[code]DestroyFunc function
AddToFunc function
I All (“A_Window”, Shaded) WindowShade Off {Break function}
I {Else} All (“A_Window”) WindowShade
This is damn simple but I don’t know how to make this “if - else” code block, I searched the forum and manpage, but nothing particular on this topic was found.
Well, as someone has already vaguely mentioned you can use “TestRc” to
evaluate whether the last executed command (i.e. the command before
the TestRc line) within a function ran or not. That is essentially the
same as saying if… else.
Mind you, if you wanted anything more specific, I would probably advise
shelling out via PipeRead, to evaluate conditions there – although unless
you’re having to evaluate the output from a command (such as
interpolation) using TestRc should suffice. It does depend on what you’re
tring to do.
