jefklak.suidzer0.org/index.php?i … loads/fvwm
If anyone is intrested, my (quite old) configuration file, but still the quite good one It includes as less as possible since I do like the fast startup times of fvwm. There’s a selfmade buttonbar on the bottom of the screen, with ACPI monitor & dell laptop CPU state monitor (both stupid selfmade scripts)
Screenshots:
jefklak.suidzer0.org/index.php?id=screenshots
Iconset is of course lila.
Some other scripts used are:
transset.c patched to get an extra argument from Xorg 6.8
Scrolling on title bars gives you a nice effect! use:
#### Wheel Toggle Shade
Mouse 4 T N Exec exec ${HOME}/.fvwm/settrans.pl $[w.id] -
Mouse 5 T N Exec exec ${HOME}/.fvwm/settrans.pl $[w.id] +
Source:
jefklak.suidzer0.org/downloads/fvwm/FvwmTransset
The dell script: - read it yust like your digitalclock & swallow as button!
[code]#!/usr/bin/perl
#my $celsius = ‘°C’;
my $celsius = ’ C’;
open(DELLINFO, “</proc/i8k”);
my $temp = (split(/\s+/, ))[3];
close DELLINFO;
printf(‘%d%s’, $temp , $celsius);
// USE IN FVWM
WindowTitle {FvwmApplet-i8k}
WindowSize 64 14 # Taille
Font “Shadow=1 se:xft:Crillee:size=14”
Init
Begin
If $MainColorset <> {} Then
Begin
End
Set $tmp = (GetOutput {exec /home/jefklak/scripts/i8ktemp} 1 -1)
ChangeTitle 1 $tmp
End
PeriodicTasks
Begin
If (RemainderOfDiv (GetTime) 60)==0 Then
Begin
ChangeTitle 1 $tmp
End
End
Widget 1
Property
Position 0 0
Size 64 14
Type ItemDraw
Flags NoReliefString
Title {}
Main
Case message of
SingleClic :
Begin
End
End[/code]
