First, in relation to the Kuickshow problem, you were right Thomas. On executing WarpToWindow, my Kuickshow window was raised. I’ve found on restarts the KuickShow window moves one page down, and one page right, and eventually disappears from your visible desktop. Don’t know if that’s an fvwm issue or a KDE issue (maybe KDE folks number the pages starting from 1).
But now that I can get my window back, it’s not so serious
Finally about the FvwmPager coredump – No luck sorry. It hangs every time I restart, but for some reason does not coredump (I recall seeing a coredump only twice so far. Since I’m in the process of writing my config, I can’t remember the settings I had when the pager core dumped).
I managed to trace the Crash on restart to a problem with RootTransparency and tinting. I used the following for my fvwm config file:
[code]
DestroyFunc StartFunction
AddToFunc StartFunction
- I exec fvwm-root --retain-pixmap ~/etc/wallpapers/png/smaug.png
- I Module FvwmConsole
- I Module FvwmPager
Key r A S4 Restart
setenv TintedLight 16
setenv TintedDark 17
setenv TintedActive 18
Colorset 15 fg #1f1f1f, bg #000000, RootTransparent
Colorset $[TintedLight] fg #808080, RootTransparent, Tint #004040 50
Colorset $[TintedDark] fg #808080, RootTransparent, Tint #010101 50
Colorset $[TintedActive] fg #808080, RootTransparent, Tint #202040 75
DestroyModuleConfig *
*FvwmPager: Colorset * 15
*FvwmPager: Geometry 200x150-10+0
*FvwmPager: SloppyFocus
*FvwmPager: MiniIcons
*FvwmPager: UseSkipList
*FvwmPager: NoDeskHilight
*FvwmPager: Hilight #ccccff
*FvwmPager: WindowColors #cccccc #777799 #ffffff #9999cc
*FvwmPager: Font none
*FvwmPager: SmallFont xft:Bitstream Vera Sans:Regular:Roman:size=6
*FvwmPager: Balloons All
*FvwmPager: BalloonBack Yellow
*FvwmPager: BalloonFore Black
*FvwmPager: BalloonFont xft:Bitstream Vera Sans:Regular:Roman:size=10
*FvwmPager: BalloonYOffset +2
*FvwmPager: BalloonBorderWidth 1
*FvwmPager: BalloonBorderColor Black
*FvwmPager: BalloonStringFormat “%t”
*FvwmPager: HilightColorset * $[TintedLight]
*FvwmPager: WindowColorsets $[TintedDark] $[TintedActive][/code]
If I comment out the Tinted colorset commands, then the restart is extreemly quick, and there is no trouble at all with the pager. However when I use the Tinted colorsets, the pager crashes on restart almost every time. (It crashes every time I press alt-tab right after the restart, and it crashes sometimes when I do nothing on a restart)
Beats me. If you know what’s going on, I’d be very appriciative. I’ve unlimited the core dump size, so if I ever get a core dump I’ll send it right along
Thanks,
GI
