I have this in my config to get a kterm at my upper left or upper right corner.
Key Up A CM Ctrl-Alt-Up-Action
Style kterm Sticky
DestroyFunc Ctrl-Alt-Up-Action
AddToFunc Ctrl-Alt-Up-Action
+ I Key Left A A Exec kterm -bg black -fg yellow -g +5+5
+ I Key Right A A Exec kterm -bg black -fg yellow -g -5+5
# optionally popup a prompt window here
+ I Schedule 5000 Key Left A A -
+ I Schedule 5000 Key Right A A -
And the same for two terms at the lover left and lower right corner.
Now i want that the same key combination shall minimize the window if its opened,
Is it possible to keep track which of my opened kterms i want to minimize, and which not.?
Or do i need to use four diffeent terminals (such as, kterm, konsole, aterm, rxvt).?
AND How do i check if a window/terminal already is opened.?
Is there a possibility check the state of a variable.?
Many ways. You could just set a window State for those you want to minimize. Of course, what you’re asking is to do something like:
Open a window if it isn’t already open.
Minimize (toggle) if it is.
So you want something like this:
DestroyFunc OpenOrIconify
AddToFunc OpenOrIconify
+ I None ($0) Exec exec $0 $[1-]
+ I TestRc (Match) Break
+ I Next ($0) Iconify
Which you would call as:
OpenOrIconify xterm -fg white -bg black, ...
And as to how you would mark which windows you would or would not wish to include in this, then you can use a window State or a different name, hence ,odifying the above:
+ I Next ($0|!"SomeName1|SomeName|SomeName3") Iconify
+ I Exec exec $0 $[1-]
Of course, this assumes you pass an appropriate -name value to the application, and the application supports it, so maybe a state would be better. Left as an exercise for you to do.
what i didn’t realy get is the $[-1] thing.
and this from the other OpenOrIconify
[code]
I Next ($0|!“SomeName1|SomeName|SomeName3”) Iconify
[/code]This didn’t i understand
i try to pseudo translate it…to see what the more FVWM-litterated will tell.
If first parameter (the name of the window) Is Equal to SomeName1|SomeName|SomeName3, then iconify the matching one.
But - what if i want to have two windows opened.?
The only thing that happen is that the opened one get iconifyed / deicoiyied.
At least - that was what happened me, but i think it’s becaus i didn’t understand how to use it completely.
Well, i got my function to work anyway, but i am not sure i did it the right way so please can someone tell me if the examples i got from Thomas Adam is the better way to go, and please can someone point me in the right direction to understand them. .
DestroyFunc Ctrl-Alt-Down-Action
AddToFunc Ctrl-Alt-Down-Action #Key Down -
I Key Left A A ToggleTerm xterm XTerm_N_Left " -bg Khaki -fg Black -g +5-5"
I Key Right A A ToggleTerm xterm XTerm_N_Right " -bg Khaki -fg SaddleBrown -g -5-5"
#+ I key Down A A ToggleTerm xterm Xterm_ScreenSession_ROOT "-bg White -fg Black -g
60x15+150+445 -fn -fixed----20-* -e sudo screen -D -R "
I key Tab A A ToggleTerm xterm Xterm_ScreenSession_ROOT "-bg White -fg Black -g
I Schedule 5000 Key Tab A A -
#+ I Schedule 5000 Key Up A A - #Key Down A CM Ctrl-Alt-Down-Action
[/code]As you see i was trying to use Down for the Xterm_ScreenSession_ROOT, but i couldn’t get it to work.
I tried to remove the key bindings for the Up/Down Keys in the beginning of the functions to not let the it be called twice, but that didn’t help. It seems as it was called twice anyway.
And - yes i sent the most of the parameters as a string because as i unsderstand it -fvwm can’t handle more than 9 parematers (or is it ten.?)
Can there be any problem doing so.?
/Dante65
I edited the post to kep it shorter - removed the almost equal code for the Up-key, and corrected some spelling errors.
So much so, you couldn’t even quote it properly. It’s $[1-] and its all positional parameters from the second one (counting from 0) to the end.
Here – have some straws to clutch. “$0” – first parameter to function, probably window name or class. !“SomeName1|SomeName|SomeName3” – If the next window in the window ring is NOT (that’s NOT) “SomeName1” OR (that’s OR) “SomeName2” OR (that’s OR) “SomeName3”, then do something. Bears no relation to $0 at all, other than $0 expands to whatever we pass into the function.
Then open them? Your original question was selectively applying some sort of toggle to some windows – and you need to mark them in some way. You could do this using states, or names/classes, as the example above tries to show you.
Pass - and I don’t care either. I can only explain the same thing in so many ways, and so far it seems your solution doesn’t cover the original problem as you stated it. But it doesn’t matter.
The language barriar, sigh - i was sure i used the correct term to describe my problem.
I understand that one can be fed up with telling the same thing once and once again … I
I have spent a few days (literally) to try understand this thing, before this posting.
