Hi, i don’t know if this is the right place to ask, but here it goes:
I want to make some keybindings and use strokes in fvwm-crystal, so i put them in the userconfig file under ~/.fvwm but it doesn’t work… i have:
Open QuakeConsole using Alt+º
Key masculine A $[Mod1] QuakeConsole
$[Mod1] is meta or alt key:
SetEnv Mod1 M
The fvwm-crystal config uses grave key (in my keyboard called dead_grave) but i want to use masculine since it’s a spanish keyb. and that’s the button placed under escape button…
Also i want to have strokes, so i put this on the file:
Mouse 1 R $[Mod0] StrokeFunc DrawMotion FeedBack StrokeWidth 1
Stroke 456 1 R N MoveToPage-Right
Stroke 654 1 R N MoveToPage-Left
This neither works… i can tell the userconfig file is read since i’ve put a
Echo —userconfig----
line there and it appears on the ~/.xsession-errors file…
All those functions exist (they are used in other parts of the config)
So… what am i doing wrong?
Thanks for the help
