Hello to all, i’m a new user of fvwm. Ive read alot of documentation about the key bindings but i cant get them to work. Well, not all of them.
The Alt-key that most of the documentation describe’s is my Windows key. But just for switching virtual desktop’s. As an example, the guake terminal will not display when pressing Win-key + , of Alt + or whatever.
Something will be/should be wroning with my xmod settings?
Any pointers would be very helpfull
(my ~/fvwm-crystal is the default)
.Xresources:
XTermbackground: black
XTermforeground: purple
XTermmetaSendsEscape: true
XTermeightBitInput: false
What’s the output from “xmodmap -pm”? Ensure you’re using the correct number for the modifier that’s in your key-bindings for FVWM. Also, turn off numlock.
Not sure what you mean. You can use “xev” to work out what’s going on, although for FVWM key-bindings, you literally just use the modifier number in your binding.
