I’m slowly learning fvwm by having used a pre-edited fvwmrc and changing things in it and seeing the results. But I haven’t been able to find anything on how to assign keybindings for changing desktops. Right now I can only change desktops by clicking on the fvwm pager, or moving the pointer to the appropriate edge of the desktop. How is this done. I found the part of fvwmrc that deals with keybindings, but apparently none of the keybindings in this setup are for changing to another virtual desktop. Can someone help me?
See the “GotoDesk” command in the fvwm manual page, this will move the viewport to a desktop.
See the “Scroll” command to move to pages within a desktop.
Wayne
Here some examples from my config:
[code]#-----------------------------------------------------------------------
press SHIFT-ALT arrow anywhere, move active
window to next/previous page
Key Left A SM FuncMoveWindowToPage -1p +0p
Key Right A SM FuncMoveWindowToPage +1p +0p
Key Up A SM FuncMoveWindowToPage +0p -1p
Key Down A SM FuncMoveWindowToPage +0p +1p
key 1-4 move current window to page n
Key 1 A SM Current FuncMoveWindowToPage 0 0
Key 2 A SM Current FuncMoveWindowToPage 1 0
Key 3 A SM Current FuncMoveWindowToPage 0 1
Key 4 A SM Current FuncMoveWindowToPage 1 1
Go to page n with SHIFT-CTRL + number
Key 1 A SC FuncGotoPage 0 0
Key 2 A SC FuncGotoPage 1 0
Key 3 A SC FuncGotoPage 0 1
Key 4 A SC FuncGotoPage 1 1
press SHIFT-CTRL arrow anywhere, and scroll by one page
Key Left A SC FuncGotoPage -1p +0p
Key Right A SC FuncGotoPage +1p +0p
Key Up A SC FuncGotoPage +0p -1p
Key Down A SC FuncGotoPage +0p +1p[/code]
And here the functions:
Move active window to next/previous page
DestroyFunc FuncMoveWindowToPage
AddToFunc FuncMoveWindowToPage
- I MoveToPage $0 $1
- I GotoPage $0 $1
GotoPage and set focus to window which is in the foreground
DestroyFunc FuncGotoPage
AddToFunc FuncGotoPage
- I GotoPage $0 $1
- I Next (CurrentPage, !Iconic, !Sticky, !Shaded, !Focused, !Overlapped) FuncSelectWindow
This function selects a window, give it the focus and raise it
DestroyFunc FuncSelectWindow
AddToFunc FuncSelectWindow
- I Iconify off
- I Focus
- I Raise[/code]
Hope this helps 8)
- Thomas -
