I have this line in my fvwmrc file: Key M A 5 Move
- this means that a mod5 key + M should trigger the Move action, right? (Back when I had it as Key M A 4 Move
it worked fine with the Windows key, which by default is Super_L which is a mod4 key, if I understand everything right.)
Today I used xmodmap to redefine my Windows key as Mode_switch, using xmodmap -e "keycode 133 = Mode_switch NoSymbol Mode_switch"
- this looks like it worked, according to xev output.
The xmodmap
command says that Mode_switch is a mod5 key: mod5 ISO_Level3_Shift (0x5c), Mode_switch (0xcb)
. So if I understand everything correctly, my Windows key, which is now Mode_switch, should count as a mod5 key, and therefore Windows+M should trigger my Key M A 5 Move
keybinding - but it doesn’t. I’m not sure which part of how this works I’m wrong about…
