cause i have a problem with my internet access and it’s easy to ask questions here than on IRC here is few issues that i can’t resolve.
How to set padding for menu? I wish to have single border in one color, then thick border in different color, and then menu items.
How to test if a variable is defined?
In my thumbnail func I set NeverFocus for thumbnail. And I can’t remove this flag whule dethumbnailing. I’ve tried with: !NeverFocus, ClickToFocus and DestroyWindowStyle and nothing
I use alltray application for Firebird traying. If I use Close function then it’s hiding into trayer. And it works fine. Unfortunately, it’s implicts Iconify as well, so I get Icon of Sunbird on my root desktop. I think, it’s alltray problem but I could (?) be resolve by Fvwm. I tried to use something like:
As far as I know you can only define one border. Make sure you have set the menu to have relief (MenuStyle * BorderWidth 1), and in the MenuColorset use a colorset that has the same colors for sh and hi.
Search the man page for the “EnvIsSet” test condition.
Post the code. It should be doable.
If the application sits on your desktkop it’s because it’s not been closed. Maybe it’s alltray segfaulting or something… I don’t really know. It’s been ages since I used a tray.
Nice. But I don’t know how to do it. Maybe it’s a patched version of fvwm or maybe it’s something with pixmaps (I never ever tried to put pixmaps on a menu so I don’t know much about the thing.
