As it is, the close, minimize and maximize buttons are on the left side of the titlebar of my applications. I would like to change them to the right side. Can someone tell me how to do this? Thanks in advance for your help.
First off, the buttons on the titlebar are made like this:
1357 Title 8642
So the paired numbers are on the right, and pairless numbers to the left.
What defines what happends on which button is defined with the lines like:
# Key ButtonNumber Context Modifier Function
Mouse 2 T A Close
Which means "Titlebar-button number 2 (the rightmost) should close the window (with "A"ny modifier). So,
Mouse 5 T M Popup Window-operations
Would popup a window-operations -menu when alt-clicked on the 3rd button from left.
After that, you can define the looks of each button. So in your case, you would just swap the buttonstyles to paired numbered buttons.
hello,
here is what i have for mine - i think it is silly to put the close window button right next to maximize, so i have it on the ither side
here is what i have in my bindings:
# Buttons left to right are numbered as in the ascii art below.
# | 1 3 5 7 9 0 8 6 4 2 |
# for the title bar buttons:
#Buttons for menu bar - pbh
Mouse 0 1 A Menu Window-Ops
Mouse 0 3 A Close
Mouse 0 2 A Maximize 100 100
Mouse 0 4 A WindowShade toggle
Mouse 0 6 A Iconify
