The owner of the screenie must have 4 gigs of ram or something like that, because the thing in the top is kicker, at least the right part (the one holding the pager and the kopete icon), the taskbar could be FvwmIconMan embeded in the same FvwmButtons where kicker is probably also swallowed.
Look the pager and the system tray with kopete… AFAIK no other tray can embed kopete sucessfully and the pager is the one from kicker with the “Elegant” style. Said that, the windows decoration could easily be also baghira and the wm kwin (though I dont know if it is possible that fvwm is running while kwin manages the windows, can anyone clariffy that?).
I suspect he is also using kdesktop. And the panel at the bottom is indeed the xfce panel. It is not a “light” desktop
in every configuration that I copy and edit for my screen and my linux (suse 10 1024x768) I’m unable to show background.
I see the thumbs on the menu, but if I click on the image, the background wont set.
–> Please scale down your screenshots, provide thumbnails or link to them, but please don’t use the img tag to include full sized screenshots on your posts, it messess up the layout for peopel with a smaller screen size, tia [/color]
Take a screenshot of one xterm under another, showing the corner cleanly. If it’s still clean, please, do post the code you’ve modified in fvwm sources.
It has a gnome-panel… that doesn’t mean it uses metacity.
Well, that wasn’t what you said… clean rounded corners are possible with cheating. Still, the problem with the borders and roottransparent colorsets under the pixmaps stands… I search for someone who wants to make the borders translucent and can do that, because I can’t.
The screenshot in that forum doesn’t look like fvwm. It has borders and rounded corners… and rounded corners without “cheating”, both things are not possible as far as I know. So it has to be a) another windowanager or b) a manipulation. I tend to a. I cannot download the fvwm2rc or the package.
After rereading that forum… I assume that the screenshot they meant is this one… although I don’t speak the language.
