I’ve put together an overly complex means of generating a help menu item that displays man pages based on the manpath variable.
It works vaguely similarly to fvwm-menu-directory. I call my script help_builder from a PipeRead to generate a menu of the directories that are in the man path. Selecting one of those directories calls the script again, passing it a specific directory. The script creates a menu with the same name as the directory. For any man pages it encounters, it puts the name of the man page as the items name, and for any directory it makes an entry that will call the script again. So selecting a man page will pop up an xterm with that man page. Selecting a directory makes it open up that directory and parse the content.
There is one small problem with my man page menus… Sometimes if I select an item, the menu doesn’t go away until I click off the menu. Then after I click off the menu, it runs the xterm command like it’s supposed to and pops up a man page. Can anyone tell me why or how to fix it?
I call it from start like this:
AddToFunc StartFunction
+ I PipeRead help_builder
I call the menu like so
AddToMenu HelpMenu
+ "Man Pages" Popup HelpMan
And here is the bash script itself:
#!/bin/bash
#MODIFY THIS TO CHANGE MENU BEHAVIOR
#MENU_COMMAND=Menu|Popup
MENU_COMMAND=Popup
# This script generates fvwm menus for man pages from the manpath.
# It is added as a PipeRead command in the start function - with no arguments
# The Menu HelpMan needs to be bound to a key or something to make it accessible
# Then when items are selected from the HelpMan menu, it calls this script and generates more menus
MAN_DIRS=`echo $MANPATH | sed s/:/\ /g`
function top_level(){
display_function
echo DestroyMenu HelpMan
echo AddToMenu HelpMan MissingSubMenuFunction DoMenu
echo AddToMenu HelpMan \"Man Pages\" Title
for DIR in $MAN_DIRS; do
if [ -d $DIR ]; then
COUNT=`ls $DIR | wc -l`
if [ $COUNT -eq 1 ]; then
FILE=`ls $DIR`;
if [ $FILE == "whatis" ] ; then
continue
fi
fi
echo AddToMenu HelpMan $DIR $MENU_COMMAND $DIR
fi
done
function second_level(){
l_DIR=$@
echo DestroyMenu $1
echo AddToMenu $1 MissingSubMenuFunction DoMenu
for DIR in $l_DIR/*; do
#if the directory has something it it, add it, otherwise we don't care
#make sure it's not just the damn index, ie whatis
FILE=`ls $DIR`;
continue
fi
elif [ $COUNT -gt 0 ]; then
echo AddToMenu $1 $DIR $MENU_COMMAND $DIR
fi
elif [ -f $DIR ]; then
if [ "`echo $DIR | rev | cut -f1 -d'/'| rev`" != "whatis" ] ; then
TITLE=`echo $DIR | rev | cut -f1 -d/|rev`
SECTION=`echo $TITLE | cut -f2 -d'.'`
TITLE=`echo $TITLE | cut -f1 -d'.'`
COMMAND="xterm -e man -s $SECTION $TITLE"
echo AddToMenu $1 \"$TITLE \($SECTION\)\" Exec exec $COMMAND
fi
fi
done
function display_function(){
echo DestroyFunc HelpManFunction
echo AddToFunc HelpManFunction
echo + I Exec exec echo \$0
echo DestroyFunc DoMenu
echo AddToFunc DoMenu
echo + I DestroyMenu \$0
echo + I PipeRead \'help_builder \$0\'
echo + I Menu \$0
if [ $# -eq 0 ]; then
top_level
elif [ $# -eq 1 ]; then
second_level $1
fi
