Why enter Gnome to do this? The Debian maintainer probably hasn’t created a .deb for 2.5.13 – downloading this from FVWM and installing it yourself is easy enough. You can even just do:
me@ubuntu:~apps/fvwm/fvwm-2.5.13$ ./configure && make deb-dist
then it does a lot of…things.
but in the end I get these messages:
FVWM Configuration:
Version: 2.5.13
Executables: /usr/bin
Man pages: /usr/share/man
Modules: /usr/lib/fvwm/2.5.13
Data files: /usr/share/fvwm
Perl lib: /usr/share/fvwm/perllib
Locale msg: /usr/share/locale ar de fr sv_SE zh_CN
With Asian bi-direct. text support? no: No fribidi-config found in PATH
With Gettext Native Lang support? yes (libc)
With GTK+ required for FvwmGtk? no: Failed to detect GTK, see config.log
With Iconv support? yes (from C library)
With Mouse strokes (gestures)? no: Can't find working libstroke
With PNG image support? yes
With ReadLine sup. in FvwmConsole? no: Can't find working libreadline
With RPlay support in FvwmEvent? no: Explicitly disabled
With Shaped window support? yes
With Shared memory for XImage? yes
With Session Management support? yes
With Xinerama multi-head support? yes
With Xft anti-alias font support? yes (version 2)
With XPM image support? no: Can't find working libXpm
With Xrender image support? yes
See INSTALL.fvwm for the description of what this may mean.
fakeroot dh_testdir -P`cd .. && pwd`/inst-2.5.13
/bin/sh: fakeroot: command not found
make[3]: *** [inplace] Error 127
make[3]: Leaving directory `/home/me/apps/fvwm/fvwm-2.5.13/fvwm-2.5.13'
make[2]: *** [deb-inplace] Error 1
make[2]: Leaving directory `/home/me/apps/fvwm/fvwm-2.5.13/fvwm-2.5.13'
make[1]: *** [this] Error 2
make[1]: Leaving directory `/home/me/apps/fvwm/fvwm-2.5.13'
make: *** [deb-this] Error 1
me@ubuntu:~/apps/fvwm/fvwm-2.5.13$ ./configure && make deb-dist
I get kind of many errormessages…is it safe to go on before I fix:
Can’t find working libXpm
me@ubuntu:~/apps/fvwm/fvwm-2.5.13$ sudo dpkg -i ./fvwm_2.5.13-0.20050807_i386.deb
(Reading database ... 135160 files and directories currently installed.)
Preparing to replace fvwm 2.5.12-4 (using .../fvwm_2.5.13-0.20050807_i386.deb) ...
Unpacking replacement fvwm ...
Setting up fvwm (2.5.13-0.20050807) ...
Installing new version of config file /etc/menu-methods/fvwm ...
Using `/usr/bin/fvwm' to provide `x-window-manager'.
