Hi
I wanted to define in my config some vertical and horizontal maximization functions respectively attached to the buttons 3 and 5 of the windows.
I did:
[code]Mouse 0 3 A Maximize-Vert
Mouse 0 5 A Maximize-Horiz
AddToFunc Maximize-Vert
AddToFunc Maximize-Horiz
Well ti works but if I maximize vertically a window and after try to maximize it horizontally, it goes back to the unmaximized state when I click on 5… Well I do not know how I can have the right behavior, that means, if I click on 3, the window is maximized vertically and then in this state, if I click on 5, I want to window to be put in full maximization!
Best regards, Brice
I suggest storing state of the window using “State” function. I don’t if there are direction to respects with these values; I used 1 to store horizontal zoom and 2 for vertical. However, to use that, any other function that perform maximization must use the functions *Zoom
[code]# State 1 : horizoom 2 : vertzoom
DestroyFunc DoHorizoom
AddToFunc DoHorizoom
- I State 1 true
- I Maximize true 100 0
DestroyFunc DoVertzoom
AddToFunc DoVertzoom
- I State 2 true
- I Maximize true 0 100
DestroyFunc DoZoom
AddToFunc DoZoom
- I State 2 true
- I State 1 true
- I Maximize true 100 100
DestroyFunc DontZoom
AddToFunc DontZoom
- I State 1 false
- I State 2 false
- I Maximize false
DestroyFunc Vertical
AddToFunc Vertical
- I Current (State 2) Function DontVertzoom
- I TestRc Function DoZoom
DestroyFunc Horizontal
AddToFunc Horizontal
- I Current (State 1) Function DontHorizoom
- I TestRc Function DoZoom[/code]
You have to bind button 3 and 5 to functions Vertical and Horizontal.
Hummm
I think some of your code is missing, i.e. DontZoomhorizoom and DontZoom isn’t used here.
But anyway merci beaucoup!!!
Brice
AAAAAHHHHHHH
definitively no ways of getting it working!!!
If someone has an idea, it’s welcome…
Regards, Brice
Hi
I got it working with the following (was quite a headache!!!):
[code]AddToFunc ZoomH
- I State 1 true
- I State 2 false
- I State 3 false
AddToFunc ZoomV
- I State 1 false
- I State 2 true
- I State 3 false
AddToFunc Zoom
- I State 1 false
- I State 2 false
- I State 3 true
AddToFunc NoZoomH
- I State 1 false
- I State 3 false
- I Maximize false 100 0
AddToFunc NoZoomV
- I State 2 false
- I State 3 false
- I Maximize false 0 100
AddToFunc NoZoom
- I State 1 false
- I State 2 false
- I State 3 false
- I Maximize false 100 100
- I Current (State 1) Function NoZoomH
- I TestRc (Match) Break
- I Current (State 2) Function Zoom
- I Current (State 3) Function NoZoom
- I TestRc (Match) Function ZoomV
- I Current (!State 1) Function ZoomH
- I Current (State 2) Function NoZoomV
- I Current (State 1) Function Zoom
- I TestRc (Match) Function ZoomH
- I Current (!State 2) Function ZoomV
AddToFunc Maximize-Full
- I Current (!State 3) Function Zoom
With that, you can maximize completely the window in 2 steps, i.e. vertically first and then horizontally, after that if you click on the mouse binding for Maximize-Vert (for example), the window goes back to the Maximize-Horiz state (after passing by the non-maximized stated unfortunately… the only thing I didn’t fix).
The Maximize-Full is used in replacement of the Maximize function.
Regards, Brice
If anyone is interested, here is my solution to the problem of “normal” horizontal/vertical maximization. It is similar to the previous solution (I also ended up using State commands), and has the same behaviour (as far as I know). I hope someone finds it useful.
[code]# resize functions
horizontal maximise
DestroyFunc Hmax
AddToFunc Hmax
- I State 1 True
- I State 2 False
- I State 3 False
- I Current Maximize True 100 0
vertical maximise
DestroyFunc Vmax
AddToFunc Vmax
- I State 1 False
- I State 2 True
- I State 3 False
- I Current Maximize True 0 100
maximise
DestroyFunc Max
AddToFunc Max
- I Current (State 3) Unmax
- I State 1 False
- I State 2 False
- I State 3 True
- I Current Maximize True 100 100
unmaximise
DestroyFunc UnMax
AddToFunc UnMax
- I State 1 False
- I State 2 False
- I State 3 False
- I Current Maximize False
horizontal maximise, toggle
DestroyFunc HorizontalMax
AddToFunc HorizontalMax
- I Current (State 1) UnMax
- I Current (State 2) Max
- I Current (State 3) UnMax
- I Testrc (Match) Vmax
- I Current Hmax
Key 7 A 4 HorizontalMax
vertical maximise, toggle
DestroyFunc VerticalMax
AddToFunc VerticalMax
- I Current (State 1) Max
- I Current (State 2) UnMax
- I TestRc (Match) Hmax
- I Current Vmax
Key 8 A 4 VerticalMax[/code]
