I’ve written a little script to produce my menu’s based on simple textfiles and while I was at it I also made it generate FvwmButtons configs to create the effect of ‘drawers’ like they used to be in Gnome 1.4 (and later I suppose).
You can generate image only buttons like these, or buttons with images and text like here or just plain text (by not specifying an image).
And you can do all that in more than one column:
I didn’t put online a sceenshot of the generated menus as I suppose you all know what an Fvwm menu looks like:wink:
Instructions on how to use it are in the script which you can download here.
TODO:
- adding the option to have icons or not, now you either have to mess in the source or live with the fact that you get icons when you specify them.
- maybe add an option to generate menus for Nick’s FvwmRingMenu.
- fix the handling of subpanels now when I close the mainpanel the subpanel stays open, this is quite ugly imho…
- other stuff I can’t think of at the moment
