Hello,
I’m using fvwm 2.5.12 and I’m trying to make two menu items that will either let me put the pager on top, or let it be covered by other windows.
This is what I am trying:
[code]DestroyFunc PagerOnTop
AddToFunc PagerOnTop
I Style FvwmPager StaysOnTop
I Recapture
DestroyFunc PagerCanBeHidden
AddToFunc PagerCanBeHidden
I Style FvwmPager StaysPut
I Recapture
DestroyMenu PagingSettings
AddToMenu PagingSettings
“Pager Always On &Top%mini.pager.xpm%” Function PagerOnTop
“Pager Can Be &Hidden%mini.pager.xpm%” Function PagerCanBeHidden
This used to work with fvwm 2.4, but doesn’t seem to work on 2.5.12. Any ideas what I need to do??
thanks.
frog-x:
I Recapture
I Recapture
thanks.
The “Recapture” command is obsolete, and has most likely been removed. What you should do is replace the Recapure command with:
UpdateStyles
Thanks. Just tried that, but it doesn’t seem to help
I think the problem is that StaysOnTop is being phased out in favour of Layers which are going to be more flexible.
Try this:
[code]
Phased out? First I’ve heard of it. “StaysOnTop” is just a convenience function to “Layer 0 6” in this instance, and still works for me on 2.5.12. The important thing here though is that “UpdateStyles” must be called from the end of the function to force an update, regardless of the methods used to keep a window raised.
Okay - I’ve changed it to:
I All (“FvwmPager”) Layer 0 6
I UpdateStyles
I All (“FvwmPager”) Layer 0 4
I UpdateStyles
and that seems to work. Thank you very much.
It does also work without the UpdateStyles lines, but I’m going to leave them in just to be certain.
That’s because you’re no longer setting any Style attributions to windows.
Aaaaah - I see. Thanks.
For interest, I’ve just tried using StaysOnTop directly, rather than using it from a menu:
I UpdateStyles
Function PagerOnTop
And this works fine. So it seems that it only doesn’t work when trying to change the StaysOnTop style for an existing window.
