Since the reinstall (and recompiling fvwm) I have a slight problem with thransparent stuff…
Reference: users.skynet.be/klak/test.jpg
Problem 1:
You can see the menu. It used to be transparent with a % shade and worked perfectly until now. I didn’t even change anything in the configuration file. Here’s the colorset used by the menu:
Colorset 0 fg #333333, fgsh #c2c4c7, bg #cccccc, hi #808080, sh #808080, Translucent #ffffff 65
Why doesn’t Tarnsculent, and “fgsh/sh” work anymore? What’s wrong, did I forget some kind of compile flag? (Using FreeBSD right now, haven’t seen special options except the stroke thing). RootTransparent works but I don’t want the menu to be COMPLETELY transp, yust a little bit shaded…
Problem 2:
Take a good look at the titlebar on the left & right. You can see “gaps” between the different PNG images. Can’t seem to fix it, it also used to work OK. Changed the titlebar colorset to RootTransparant and got this (without it it’s even uglier: borders around every image! Argh). Colorset and snipped of code:
[code]Colorset 2 fg #867a60, RootTransparent, IconAlpha 60, fgsh #d2cbba
DestroyDecor DefaultDecor
AddToDecor DefaultDecor
- TitleStyle AllActive StretchedPixmap $[fvwm_home]/themes/$[fvwm_theme]/titlebar/back_active.png
- TitleStyle AllInactive StretchedPixmap $[fvwm_home]/themes/$[fvwm_theme]/titlebar/back.png
- TitleStyle – flat
- TitleStyle Height 21
- ButtonStyle All – flat
- ButtonStyle 1 - MwmDecorStick
- ButtonStyle 2 - Clear
- ButtonStyle 4 - MwmDecorMax
Left button: window properties
- AddButtonStyle 1 ActiveUp (Pixmap $[fvwm_home]/themes/$[fvwm_theme]/titlebar/1_active.png – flat)
Style * UseDecor DefaultDecor[/code]
Changing the TitleStyle Height to 18 solves the height difference but the little tiny “gaps” between the minimize, maximize and close buttons (take a good look, hehe) are still there and the are extremely annoying…
Help
