Colorsets (I think it was Ikaro’s mercx fluxbox theme that inspired me)
Desktop icons handled by ROX pinboard
an FVWM background menu can change the pinboard background using SOAP
Stuff I don’t like:
I should bite the bullet and use 16x16 icons for the iconmanager
I prefer svg icons, but it makes it confusing when I need to throw in an icon that isn’t
I haven’t decided on a color scheme for the pager
my imagemagick’s composite doesn’t seem to work like it used to… no little icon on top of the window (I haven’t put much time in it since I just switched back to PNG icons)
If you download the config, be careful not to write over your existing fvwm…
DestroyFunc StartFunction
AddToFunc StartFunction
+ I Module FvwmButtons FvwmPanel
+ I Module FvwmEvent
+ I Module FvwmCommandS
+ I Module FvwmButtons FvwmDock
+ I Exec exec rm -rf $[FVWM_USERDIR]/tmp/*
+ I Test (Init) Exec exec gnome-settings-daemon &
+ I Test (Init) Exec exec xset -b
+ I Test (Init) Exec exec rox --pinboard=Fvwm
+ I Test (Init) Function FuncEffectsOn
+ I Test (Restart) All (Iconic) ReThumbnail
Exit too? I guess it doesn’t really matter but does that mean it will execute my first five commands before exiting? It just seems a little odd… there’s probably something I’m missing.
