Hi everybody!
I’m having problems to get miniicon over thumbnails only for certain apps: OO 1.1.4, Azureus, aMule, Limewire and GMPlayer basically.
I have these styles in my config:
Just keep defining them a new icon in the same manner, above – match by class if you like, especially for things like mplayer – FvwmIdent might hekp you there.
Thank you ThomasAdam…The problem is that I’m really new to Fvwm and I’m studying a pre-made .fvwmrc to learn a little bit.
I’m using a KDE+Fvwm solution at the moment and the FvwmIdent that I got with the config file doesn’t seem to work…( pop-up a black little-window ).
What should I do to solve the MiniIcon problem?
Open a FvwmConsole and type :
Module FvwmIdent
Then you need to click into the window you want and a little window will appear with all informations you need (class, ressource etc).
The only app that doesn’t seem to work with MiniIcon is Writer: using FvwmIdent I get a Class: OpenOffice.org 1.1.4 , but if I use it in config it doesn’t work.
The (little) more I learn about this WM the more I love it…Thank you!!!
Oops. Second one doesn’t work after all - it only works if the window is already up and I restart. So when I did, I assumed it was working but it turns out it’s only a one shot. I’m too tired to figure it out now.
