For some reason the MiniIcon in the taskbar is only shown when I iconify a given window. The icon doesn’t show up until I iconify the window, and it dissappears again as soon as I iconify it off again. I guess that the question is “where [1] should I be looking at?”
Thanks.
[1] pastebin.es/16355
$ fvwm --version
fvwm 2.5.27 (from cvs) compiled on Feb 11 2009 at 08:43:01
with support for: ReadLine, XPM, PNG, Shape, XShm, Xinerama, XRender, XCursor, XFT, NLS
Sigh. You’re confused.
*FvwmIconMan: DrawIcons True
No. no, no. You want:
*FvwmIconMan: DrawIcons Always
Whislt I am at it, there’s some other things your config could do with amending.
+ I ThisWindow WindowStyle BorderWidth 2, HandleWidth 2
Get rid of “ThisWindow” – the function’s already in the correct window context at the time it’s called.
DestroyFunc FvwmMoveToLayer
AddToFunc FvwmMoveToLayer
+ I Layer 0 $0
+ I ColorizeLayers
+ I UpdateStyles
+ I Raise
UpdateStyles? Here? When no styles are changed. That line belongs in ColorizeLayers – having it here is going to cause a window recapture at the wrong time which is going to cause a lot of flicker. (The use of UpdateStyles is arguarbly redundant nowadays anywhere, given {Window}Style lines are always applied.
Style * BackColor #efebe7, ForeColor #afaca7
+ I All (Layer 6) WindowStyle HilightBack #059605, BackColor darkgreen
Can you please not use BackColor? It’s going the way of the dodo soon.
You’ve a number of DestroyModuleConfig lines:
DestroyModuleConfig FvwmIconMan
Generally speaking, you should always have it in the form:
DestroyModuleConfig alias:*
Thank you, Thomas. That was the problem indeed. Problem solved.
I’ve also cleaned the config a bit using the rest of your suggestions.
