When FVWM calls fvwm-menu-directory it passes an empty string as $1 instead of the second argument.
However when I call fvwm-menu-directory from command line like below in the way I’d expect FVWM to call it, it works as it should.
% fvwm-menu-directory -d '~' --func-name 'funcFiles' --filexts 'csv,csv,html,acgi,htm,htmls,htx,shtml,stm,mml,txt,text,conf,def,list,log,c,c++,cc,com,cxx,f,f90,for,g,h,hh,idc,jav,java,lst,m,mar,pl,sdml,bas,in,asc,diff,pot,el,ksh,rtf,tsv,xml,dot,lwp,wks,wp,wp6,oprc,otm,wpd,docm,dotx,ott,wdb,dotm,w6w,wiz,word,oth,wcm,doc,sgl,sxg,rtx,docx,wp5,odm,wps,stw,sxw,odt,pqa,pdb,sxm,mathml,odf,odft,odb,xhtml,xul,xht,wk,xld,xll,ots,xlsb,xlc,xla,xlb,123,xl,ods,xlt,odc,otc,wk1,xlm,xlw,xltm,xltx,xlv,xlsx,xls,stc,xlsm,xlk,sxc,xz,jar,rpm,cpio,cbt,tar,zip,cbz,cb7,rar,gzip,cab,sit,gtar,z,7z,cba,taz,tgz,lha,cbr,gz,bz,bcpio,boz,bz2,sv4cpio,sv4crc'
This is the menu in the fvwm config (created by my script):
[code]AddToMenu meowFiles MissingSubmenuFunction funcFiles
- “Text” Popup ~ csv,csv,html,acgi,htm,htmls,htx,shtml,stm,mml,txt,text,conf,def,list,log,c,c++,cc,com,cxx,f,f90,for,g,h,hh,idc,jav,java,lst,m,mar,pl,sdml,bas,in,asc,diff,pot,el,ksh,rtf,tsv,xml,dot,lwp,wks,wp,wp6,oprc,otm,wpd,docm,dotx,ott,wdb,dotm,w6w,wiz,word,oth,wcm,doc,sgl,sxg,rtx,docx,wp5,odm,wps,stw,sxw,odt,pqa,pdb,sxm,mathml,odf,odft,odb,xhtml,xul,xht,wk,xld,xll,ots,xlsb,xlc,xla,xlb,123,xl,ods,xlt,odc,otc,wk1,xlm,xlw,xltm,xltx,xlv,xlsx,xls,stc,xlsm,xlk,sxc,xz,jar,rpm,cpio,cbt,tar,zip,cbz,cb7,rar,gzip,cab,sit,gtar,z,7z,cba,taz,tgz,lha,cbr,gz,bz,bcpio,boz,bz2,sv4cpio,sv4crc
- “Image” Popup ~ bmp,bm,g3,gif,jpeg,jpg,jfif,jfif-tbnl,jpe,jfif,jpe,jpeg,jpg,png,x-png,svg,svgz,tiff,tif,rp,wbmp,ras,fh,fhc,fh4,fh5,fh7,ico,bmp,pcx,pnm,pbm,pgm,ppm,tga,xbm,xpm,xbm,xpm,pm,xwd,xbm,xpm,std,odg,sxd,vsd,vss,otg,vsw,vst,ani,pdf,ps,eps,ai,chm,oxps,xps,pot,pwz,pptx,otp,ppsx,potx,ppsm,sxi,ppz,sldx,odp,potm,pptm,ppt,pps,ppa,sti
- “Audio” Popup ~ flac,mp4a,m4a,mpga,mp2,mp2a,mp3,m2a,mpa,mpg,m3a,mpega,m4a,m3u,oga,ogg,spx,weba,snd,flac,mka,mp2,m3u,wax,wma,ram,ra,rm,rmm,rmp,rmp,ra,rpm,pls,wav
- “Video” Popup ~ avi,mp4,mp4v,mpg4,mpeg,mpg,mpe,m1v,m2v,mp2,mp3,mpa,mpv2,avi,qt,moov,mov,rv,webm,fli,flv,mkv,mk3d,mks,mp2,mp3,asf,asx,asr,wmv,avi,rm,m2a,ra,m4a,pls,m3a,oga,mp2a,wav,mp4a,ogg,rmm,spx,snd,m3u,flac,mpga,rmp,wma,ram,mka,mpega,ogx,wax,rp,weba,xspf,rpm,swfl,swf
- “All” Popup ~ *
AddToFunc funcFiles
- I PipeRead “fvwm-menu-directory -d ‘$0’ --func-name ‘funcFiles’ --filexts ‘$1’”[/code]
Any idea what mistake I made?
