fvwm-mpd
Requirements: imlib2, mpd, mpc (ncmpc is optional)
I think this is at the point where it’s stable, bug free, and light on resources, so I’m “releasing” it. It looks something like this:
It has normal previous/play/pause/stop/forward controls as well as a control to pop up a playlist (I suggest ncmpc, shown in the image above). It also shows a small image of the cover art which, when clicked on, brings up a window with the artist and album name, and a larger picture.
NOTE: You must specify a value for an environmental variable called CoverArt. For example, put the following line in your fvwm config somewhere:
and replace cover.jpg with the filename of the cover art in your music directories.
The layout of files should be something like:
~/.fvwm/
scripts/
CoverArt
FileExists.sh
mpdSongName
resize
images/
mpd/
Any questions, problems, or suggestions, please ask.
