Uploading: 2022-05-23_23-00.png…
All settings done in shell script and lua.
Nice. Can you post the script for window decoration and the bottom panel?
Of course, I changed the Fvwm configuration scripts from lua to shell, I’ll add it to github and leave the link here, but my git is kind of disorganized, but I’m working on it.
I downloaded the git zip archive. For my information, two questions:
To have an idea of what your ~/.fvwm/config does, I am running it as ~/.fvwm/local.config
In fact, I copy the binaries from Fvwm and leave it in my home, and send it to this github repository, so that if there is a problem with the compilation, or with the AUR, I already have the binaries compiled. In case to use this configuration, just copy the file “fvwm-conf” cp -r fvwm-conf ~/.fvwm to have the configuration of fvwm, for the bar you must copy the file “eww” cp -r eww ~ /.config and so will the bara. In this configuration the fvwm is almost entirely configured in .fvwm/settings.sh.
Very nice, I like your window style. The github links you provide don’t seem to work, however. Is there another way to have a look at the config?
