Here is my config, i’ve stole some ideas from lucky’s config, now i have only a dock and a pager, but i’m trying to personalize the config to be fast and gook looking.
Thanks to Enzo for the icon!
Cool. Your screenshot 404s, and you don’t supply your config either, which you ought to.
Try again.
I’m sorry, i’d linked the wrong img…
Now it’s ok
The config isn’t finished but if you want it, tell me. I’ll post it.
Configs are never truly finished anyway, so I wouldn’t worry about that:)
Yes, i’ve the same icon set!
But the base config is a lucky’s one
