My .fvwm2rc
Well for what it’s worth here is mine and I would like to thank those that helped me and the man pages and the info pages and of course ‘google’ and ‘git hub’. I broke up my stuff into different files, made it way easier to work with. What I’ve done here is between the “(( ))” is the actual coding.
I’ve got it working the way I wanted it to, I’m sure there are some more aesthetic tweeking and some little glitches but it works.
[code]#-----------------------------------------------------------------------------\
__ _ _ _ ___ |
#/ | |_ __ _ | | _____ ( ___ /__ ___ __ |
#\ | '_ \ / |/ _ |/ _ \ \ /\ / |/ _| // /\ \ /\ / | ’ \ |
\ | | | | (| | (| | () \ V V / _ \ / _// \ V V /| | | | |
#_|| ||_,|_,|_/ _/_/ |/ ___/ _/_/ || || |
__ ____ |
/ ___ ___ ___ __ ___ |___ \ _ __ ___ |
| |\ \ / \ \ /\ / | ’ ` _ \ ) | '/ __| |
_| _|\ V / \ V V /| | | | | |/ /| | | ( |
#(|| _/ _/_/ || || ||_____|| ___| |
__ ____ __ ____ |
/ | ___ _ __ __ _____ _ __ |__ \ / /_ | ___| |
#| |_ / _ | '| \ \ / / _ | '| ) || ’ \ |__ \ |
#| | () | | \ V | | | / / | () _ ) | |
| _
| _/ _
__(__(|___/ |
For those that, care the ascii letters are from |
http://patorjk.com/software/taag/#p=display&h=3&v=0&f=Ogre |
As an added bonus to this little endeavor, it’s also made |
me very familiar with my now favorite editor ‘G/VIM’. |
I’ve commented the hell out of this for myself incase I have |
to come back to this later on and for anyone |
who might find it helpful, useful or just too lazy to bounce |
back and forth between the man pages and FVWM home pages |
#—NB: if you really bork things up |
where the default stuff setting scripts and forms are |
fvwm-config --info | grep Data |
#…Now! On with that show! |
ENVIRONMENT VARIABLES
SetEnv fvwm_home $[HOME]/.fvwm
SetEnv fvwm_img $[fvwm_home]/images
SetEnv fvwm_icon /usr/share/icons
SetEnv fvwm_pix /usr/X11R6/share/pixmaps
SetEnv fvwm_wall ~/Pictures
SetEnv fvwm_script $[fvwm_home]/scripts
SetEnv fvwm_icon_size 48
GLOBAL OPTIONS
OpaqueMoveSize -1
Emulate FVWM
#Mwm and Win style menus popup sub menus automatically.
#Win menus indicate the current menu item by changing the background to black.
#Fvwm sub menus overlap the parent menu, Mwm and Win style menus never
#overlap the parent menu
HideGeometryWindow Never
BugOpts FlickeringMoveWorkAround True
XorValue 55555
#Animation set to 30ms with 16 frames
SetAnimation 30 -.01 0 .01 .03 .08 .18 .3 .45 .6 .75
.85 .90 .94 .97 .99 1.0
SHELL SETTING
#Test for tcsh and then uses it
Test (f /bin/tcsh)
ExecUseShell /bin/tcsh
IMAGE, ICONS, ETC
#the entry with xxx;.png means to look for png files in the same location
#the default files used are .xpm
ImagePath $[fvwm_img]:$[fvwm_img];.png:$[fvwm_icon]:$[fvwm_icon];.png:
$[fvwm_pix]:$[fvwm_pix];.png+
BANNER
*FvwmBanner: NoDecor
#tests to see if the file is available
#if not it reverts back to default
#Yeah, I ‘had’ to make my own :sunglasses:
Test (I banner.xpm)
*FvwmBanner: Pixmap Banner.xpm
*FvwmBanner: Timeout 3
SCREENSAVER
start xscreensaver daemon for locking
  • I Test (x xscreensaver-command) Test (Init) Exec xscreensaver -no-splash
WIN_IDENT
xwininfo boxes
*FvwmIdent: Fore DeepPink4
*FvwmIdent: Back SlateGray4
*FvwmIdent: Font “xft:Sans:Bold:size=10:antialias=True”
PAGER
#setups up # of pages
#|0|1|2|
Module FvwmPager 0 2
#+0+0 = TL corner
#-0-0 = BR corner
#+1-1 = BL corner
#-1+1 = TR corner
FvwmPagerGeometry 190x50-1+1
FvwmPager: MiniIcons
FvwmPager: Back Black
FvwmPager: Fore DeepPink1
FvwmPager: Font -adobe-helvetica-bold-r--
-10-
#Hilights the active desktop and page
*FvwmPager: Hilight White
*FvwmPager: Balloons All
*FvwmPager: BalloonsFore red4
*FvwmPager: BalloonsBack black
#*FvwmPager: BalloonColorSet * Colorset 9
#*FvwmPager: BalloonsBack Yellow
#*FvwmPager: BalloonsBack Black
  • Fvwmpager: BalloonFont “xft:Bitstream Vera Sans:style=Roman:size=8:antialias=True”
    #*FvwmPager: BalloonsFont lucidasanstypewriter-8
    *FvwmPager: BalloonsOffset +2
    *FvwmPager: BalloonBorderWidth 1
    #*FvwmPager: BalloonBorderColor red4
VIRTURAL DESKTOPS
(0) (1) (2)
#|00|01| | | | |
#|10|11| | | | |
DeskTopSize 2x2
DesktopName 0 Home
DesktopName 1 Whirk
DesktopName 2 Serphin
EdgeScroll 100 100
EdgeThickness 1
#Have cursor resist for #ms before going to the next desktop
EdgeResistance 2000
Style * EdgeMoveDelay 1500
Style * EdgeMoveResistance 1500
COLORSETS
#Warning: The highest colorset number used determines memory consumption.
#Thus, if you define ‘Colorset 100000’, the memory for 100001 colorsets is used
#Colorset N | Meaning | Usage Examples
0 | default | feedback windows, FvwmScroll
1 | inactive window | window/icon titles, windows in Pager
2 | active window | window/icon titles, windows in Pager
3 | inactive borders | window borders (may copy 1)
4 | active borders | window borders (may copy 2)
5 | inactive menu item | menus (may have pixmap or gradient)
6 | active menu item | menus (only bg/fg used)
7 | greyed menu item | menus (only fg used)
8-9 | reserved | for the fvwm-themes future use
10 | modules, default | Button Bar, Pager, other modules
11 | modules, default hilight | Button Bar
12 | modules, special | gradient for IconMan/IconBox
13 | modules, swallowed apps | bg, fg, sh, hi for xclock/xload etc.
14 | modules, default #2 | alternative for Pager, Button Bar
15 | modules, default hilight #2| alternative for Pager
16 | modules, balloons | TaskBar, Pager
17 | modules, winlist, standard | item of IconMan, WinList, TaskBar
18 | modules, winlist, active | --.–
19 | modules, winlist, iconified| --.–
20 | modules, winlist, pointed | --.–
21 | modules, ident | FvwmIdent
22 | modules, console | FvwmConsole
23 | modules, transparent | Button Bar
24-28 | modules, reserved | for the fvwm-themes future use
29 | dynamical/temporary | tools for choosing/previewing colors
30 | regular terminal | xterm/rxvt or any other terminal
31 | admin terminal | terminal for root (su)
32 | remote terminal | terminal with ssh/rsh/telnet
33 | viewer terminal | man, less, tail -f
34 | console application | top, editor
35 | dialog main area | FvwmScript, FvwmForm, xmessage
36 | dialog text area | FvwmScript, FvwmForm, xmessage
37-39 | reserved | for the fvwm-themes future use
Colors can be #hex or rgb.txt oneword names
ColormapFocus FollowsMouse
Colorset 0 fg “lawn green”, bg black
Colorset 1 fg green, bg red4
Colorset 2 fg black, bg SkyBlue4
Colorset 3 fg dimgray, bg black
Colorset 4 fg black, bg #00FF11
#[TODO] Colorset 5 set to dark-stone pixmap.
Colorset 6 fg #FFFF33, bg #CC3333
Colorset 7 fg red4
#[Test this one on diff. locations]
Colorset 8 transparent
Colorset 9 BGradient 300 Black SaddleBrown
#Gradient Types
#C=Center->Out
#B=BR to TL
#D=TL to BR
#R=CCW Radial
#S=‘X’ out to in
#Y=yinyang
Colorset 10 DGradient 300 Black Red
TASKBAR
Rem’d out for later use for eye candy purposes
#*FvwmTaskbar: StartName Oh yea! $[fvwm_img]/16x16/others/animals-penguin.png
___ _ _
/ __ | || | ___ _ __ ___
/__/| | | | __| _/ _ | ’ / __|
#/ / | || | || || () | | | _
#_/_,|_|__/|| ||_/
read kage.buttons
A x B = A=<> B=^v
DestroyModuleConfig FvwmButtons: *
*FvwmButtons: Geometry 165x620+1740+64
*FvwmButtons: font “Shadow=1:xft:Sans:Bold:pixelsize=9:minspace=True:antialias=True”
*MyButtons: Boxsize fixed
#| C1/R1 |…|C3/R1 |
#| C1/R13|…|C3/R13|
*FvwmButtons: Columns 3
*FvwmButtons: Rows 13
#http://stalonetray.sourceforge.net/about.html for the systray in the button
*FvwmButtons: (2x1, Back red4, Swallow stalonetray ‘Exec exec stalonetray -t --fuzzy-edges 3 --geometry 5x2 -i 20 --vertical --dockapp-mode simple’)
*FvwmButtons: (Colorset 1, Icon $[fvwm_img]/png/24x24/apps/Terminal.app.png,
Action (Mouse 1) Exec exec xterm -fg cyan -bg black -geometry 80x24,
Action (Mouse 3) Exec exec xterm -fg green -bg black -geometry 90x60)
*FvwmButtons: (Colorset 1, Icon $[fvwm_img]/png/16x16/apps/firefox.png
Action (Mouse 1) ‘Exec exec /usr/lib/firefox-34.0.5/firefox-bin -new-tab’,
Action (Mouse 3) ‘Exec exec firefox -new-tab http://www.slackbuilds.org’)
*FvwmButtons (Back Black, Icon$[fvwm_img]/mini/sound.xpm
Action (Mouse 1) ‘Exec exec aumix’)
*FvwmButtons: (Colorset 1, Icon $[fvwm_img]/winXX-startmenu/documents.xpm
Action (Mouse 1) ‘Exec exec konqueror’,
Action (Mouse 3) ‘Exec exec dolphin --split’)
*FvwmButtons (Colorset 1, Icon $[fvwm_img]/png/24x24/apps/gvim.png
Action (Mouse 1) ‘Exec exec gvim’,
Action (Mouse 3) ‘Exec exec kwrite’)
*FvwmButtons: (Back black, Icon $[fvwm_img]/winXX-startmenu/help.xpm
Action (Mouse 1) ‘Exec exec xman -pagesize 875x875+0+0 -bg black -fg cyan -bd red -title RTFM!’)
*FvwmButtons (Colorset 1, Icon $[fvwm_img]/png/24x24/apps/gimp.png
Action (Mouse 1) ‘Exec exec gimp’,
Action (Mouse 3) ‘Exec exec gwenview’)
*FvwmButtons (Colorset 1, Icon $[fvwm_img]/png/24x24/apps/vlc.png
Action (Mouse 1) ‘Exec exec vlc’,
Action (Mouse 3) ‘Exec exec xine’)
*FvwmButtons (Back black, Icon $[fvwm_img]/png/24x24/apps/xmms2.png
Action (Mouse 1) ‘Exec exec xmms’),
Action (Mouse 3) ‘Exec exec audacious’)
*FvwmButtons: (Back red4, Icon $[fvwm_img]/png/24x24/actions/view-media-artist.png,
Action (Mouse 1) ‘Exec exec xterm -r -e $[fvwm_script]/toor.scr’)
*FvwmButtons (Back red4, Icon$[fvwm_img]/exit6.xpm
Action (Mouse 1) Quit,
Action (Mouse 3) Restart
Rem’d since this is a dup of what’s on .buttons
Action (Mouse 2) Exec exec xscreensaver-command -lock)
*FvwmButtons: (Back black, Icon $[fvwm_img]/mc.xpm,
Action (Mouse 1) ‘Exec exec $[fvwm_script]/mc.scr’)
*FvwmButtons: (Colorset1, Icon $[fvwm_img]/48x48-infox/disk-cd.xpm,
Action (Mouse 1) ‘Exec exec $[fvwm_script]/dvdon.scr’),
Action (Mouse 3) ‘Exec exec $[fvwm_script]/dvdout.scr’)
#size is set to 3 row x 2 col.
*FvwmButtons: (3x2, Back red4, Swallow “oclock” ‘Exec oclock -jewel green -hour white -minute white -bg red4 -transparent’)
*FvwmButtons (3x2 Container())
*FvwmButtons: (3x1+0+0, Swallow (NoKill, Respawn, UseOld) “xclock” ‘Exec xclock -digital -face ‘Mononspace:size=16’ -bg red4 -fg white -strftime " %a %m-%d"’)
#fg=pupil outline=around eye
*FvwmButtons: (3x1+0+1, Back red4, Swallow “xeyes” ‘Exec exec xeyes -fg CornflowerBlue -outline black -bg green’)
*FvwmButtons (End)
#This creates a container box within the existing Buttons Window
#that takes up 3 col and 3 rows.
#1x1 = 1 col x 1 row within the created block and then the location of the item
#within the created box, eg. +1+2 would put it in column 1
#row 2 (remember - start with ‘0’)
*FvwmButtons (3x4, Container(Rows 4, Columns 5))
#| 00 | 10 | 20 | 30 |
#| 01 | 11 | 21 | 31 |
#| 02 | 12 | 22 | 32 |
*FvwmButtons (1x1+0+0, Back red4, Icon $[fvwm_img]/mini/mini.resize.xpm Action Resize)
*FvwmButtons (1x1+1+0, Back red4, Icon $[fvwm_img]/mini/mini.move.xpm Action Move)
*FvwmButtons (1x1+2+0, Back red4, Icon $[fvwm_img]/mini/mini.lower.xpm Action Lower)
*FvwmButtons (1x1+3+0, Back red4, Icon $[fvwm_img]/mini/mini.raise.xpm Action Raise)
*FvwmButtons (1x1+4+0, Back red4, Icon $[fvwm_img]/mini/mini.excl.xpm Action ButtonRestart)
*FvwmButtons (1x1+0+1, Back red4, Icon $[fvwm_img]/mini/mini.stick.xpm Action Stick)
*FvwmButtons (1x1+1+1, Back red4, Icon $[fvwm_img]/mini/mini.delete.xpm Action Delete)
*FvwmButtons (1x1+2+1, Back red4, Icon $[fvwm_img]/mini/mini.destroy.xpm Action Destroy)
*FvwmButtons (1x1+3+1, Back red4, Icon $[fvwm_img]/mini/mini.iconify1.xpm Action Iconify)
*FvwmButtons (1x1+4+1, Back red4, Icon $[fvwm_img]/png/16x16/actions/system-lock-screen-2.png
Action (Mouse1) ‘Exec exec xscreensaver-command -lock’)
*FvwmButtons (1x1+0+2, Back red4, Icon $[fvwm_pix]/htop.png
Action (Mouse1) ‘Exec exec xterm -geometry 165x85 -e htop’)
#*FvwmButtons (1x1+1+2, Back red4, Icon $[fvwm_icon]/hicolor/16x16/apps/knotes.png
Action (Mouse1) ‘Exec exec knotes’
*FvwmButtons (2x1, Back red4, Swallow (UseOld,NoKill,Respawn) “wmxmms” ‘Exec exec wmxmms’)
*FvwmButtons (2x1, Back red4, Swallow (UseOld,Hints,Respawn) “wmweather” ‘Exec exec wmweather’)
*FvwmButtons (End)
#<><><______________________>
__ _ _
#/ \ | _ | | ___ ___
#\ | __| | | | |/ _ / __|
\ \ || || | | /_
#_/_|_, ||_
||__/
|___/
read kage.styles
<kage.styles>
for reminder these are set in .fvwm2rc
#fvwm_img $[fvwm_home]/images
#fvwm_icon /usr/share/icons
#fvwm_pix /usr/X11R6/share/pixmaps
#COLORSET is done in .fvwm2rc
Global
http://www.fvwm.org/doc/unstable/commands/Style.html
#Have to click window to bring it forward
#SloppyFocus sets window active when cursor is on window
#not my glass of vodka, personally
#[TODO] Need to experiment with these settings
#Style * NoIcon
Style * ClickToFocus
Style * Font --clean-bold-r---17-------
Style * IconFont -adobe-courier-bold-r---14-100--100----*
Style * HilightFore “lawn green”, HilightBack cornflowerblue
Style * BorderWidth 7, HandleWidth 7
Style "" Icon Unknown.xpm, Color lightgrey/dimgrey
Style * MWMFunctions, MWMDecor, HintOverride
Style * DecorateTransient, NoPPosition
Style * IconBox 0 -10 -280 -1
Style * FocusFollowsMouse
Style * TileCascadePlacement
Style Fvwm
NoTitle, Sticky, WindowListSkip
Style Fvwm* BorderWidth 2, CirculateSkipIcon, CirculateSkip
#Style FvwmPager StaysOnTop - set so it will go under open windows
#see kage.pager-todo
Style FvwmBanner StaysOnTop
Style FvwmButtons Icon toolbox.xpm, ClickToFocus
Program
Starts on (deskop window window)
Style * = set all entries to whatever setting
eg. Click to Focus ANY application
Style “Firefox” Icon firefox.png, MiniIcon $[fvwm_icon]/oxygen/16x16/apps/internet-web-browser.png, StartsOnPage 2 0 0
Style “xterm” Icon $[fvwm_img]/term.xpm, MiniIcon $[fvwm_icon]/nuvola/16x16/apps/utilities-terminal.png, StartsOnPage 1 0 0
Style “xmms” StartsOnPage 2 1 1
by Shadow Style XTerm Icon $[fvwm_img]/term.xpm, MiniIcon $[fvwm_icon]/hicolor/16x16/apps/terminator.png,\
ClickOnFocus, IconBox -70 1 -1 -140
Style “kwrite” Icon $[fvwm_img]/png/24x24/apps/kwrite.png
Style “konqueror” Icon $[fvwm_img]/konqueror.png
Style “knotes” Icon $[fvwm_icon]/oxygen/32x32/apps/knotes.png
Style “kalarm” Icon $[fvwm_icon]/nuvola/22x22/actions/kalarm.png
Style “wmweather” NoTitle, NoHandles, Sticky, WindowListSkip, ClicktoFocus, StaysOnBottom
WINDOWS[TODO]
#Style" UseDecor k_decor
#Style "
” Font --
#Style "
" Colorset
MENU
Colorset5 | inactive menu item | menus (may have pixmap or gradient)
MenuStyle * fvwm
MenuStyle * MenuColorset 6
MenuStyle * TitleColorset 2
MenuStyle * HilightBack black
MenuStyle * TitleWarp, TitleUnderlines1
MenuStyle * Sidepic $[fvwm_img]/side.fvwm2.xpm, SideColor #000000
MenuStyle * Icon $[fvwm_img]/linux.xpm
#[TODO] MenuStyle * Itemformat
#MenuStyle * Foreground IndianRed3, Background black, Greyed grey40, Hilightback white, ActiveFore #b80909
MenuStyle * Font --clean-bold-r---17-------
#MenuStyle * Font “xft:Candara:Bold:size=10:minspace=False:antialias=True”
CURSOR_STYLE
CursorStyle DEFAULT $[fvwm_img]/HandPointing.xpm 0 0
CursorStyle ROOT $[fvwm_img]/HandPointing.xpm 0 0
#title was set just to be funny - could of been set just like default one
CursorStyle TITLE $[fvwm_img]/png/16x16/emotes/face-devilish.png 0 0
CursorStyle MOVE $[fvwm_img]/HandReach.xpm 0 0
CursorStyle MENU right_ptr
#[TODO]
#CursorStyle DESTROY #Look here for some nostalgic X cursors http://www.google.com/url?sa=i&rct=j&q=&esrc=s&frm=1&source=images&cd=&cad=rja&uact=8&docid=wQc08sTQ3xXvMM&tbnid=sNMpEvXUbKkBvM:&ved=0CAYQjB0&url=http%3A%2F%2Fdocstore.mik.ua%2Forelly%2Fperl3%2Ftk%2Fch23_02.htm&ei=n4IpVM-gCuGr8gHblYDgDw&bvm=bv.76247554,d.aWw&psig=AFQjCNF9h0eCs3xAroLPLZ84-M8f5h18Dw&ust=1412092747818624
#CursorStyle TOP_LEFT
#CursorStyle TOP_RIGHT
#CursorStyle BOTTOM_LEFT
#CursorStyle BOTTOM_RIGHT
BUTTON STYLE
Button identification is set in kage.binding
#This will set all active and inactive to raised or flat respectively
ButtonStyle All Active (-- raised) Inactive (-- flat)
ButtonStyle 1
Active (AdjustedPixmap $[fvwm_img]/png/16x16/actions/align-vertical-top.png)
InActive (AdjustedPixmap $[fvwm_img]/png/16x16/actions/align-vertical-top.png)
ButtonStyle 2
Active (AdjustedPixmap $[fvwm_pix]/Daemon.xpm)
InActive (AdjustedPixmap $[fvwm_pix]/Daemon.xpm)
ButtonStyle 3
Active (AdjustedPixmap $[fvwm_img]/48x48-infox/window-iconify.xpm)
InActive (AdjustedPixmap $[fvwm_img]/48x48-infox/window-iconify.xpm)
ButtonStyle 4
Active (AdjustedPixmap $[fvwm_img]/48x48-infox/window-maximize.xpm)
InActive (AdjustedPixmap $[fvwm_img]/48x48-infox/window-maximize.xpm)
k_decor
DestroyDecor k_decor
AddToDecor k_decor
TitleStyle RightJustified Height 20
TitleStyle Active (TiledPixmap $[fvwm_img]/buttons/bluegray-gimpressionist-cubism.xpm – Raised )
TitleStyle Inactive (TiledPixmap $[fvwm_img]/background/as-back.xpm – Sunk )
//\ ___ _ __ _ _ ___
/ \ / _ \ '_ | | | / __|
#/ //\ \ / | | | || _
#/ /_
|| ||_,|___/
read kage.menu
<kage.menu>
DestroyMenu MenuFvwmRoot
AddToMenu MenuFvwmRoot “[Kage’s Menu]” Title
  • “[AudVid]” Popup MenuFvwmAudVid
  • “[Dev]” Popup MenuFvwmDev
  • “[0.25]” Popup MenuFvwmGames
  • “[911]” Popup Help
  • “[Whirk]” Popup MenuFvwmOffice
  • “[Proggies]” Popup MenuFvwmPrograms
  • “[Tools]” Popup MenuFvwmTools
    #+ “[Utiz]” Popup MenuFvwmUtilities
  • “Volume” Popup Volume
  • “[Webbing]” Popup MenuFvwmWeb
  • “[Bu-Bye]” Popup MenuFvwmQuitVerify
AudVid Menu
DestroyMenu MenuFvwmAudVid
AddToMenu MenuFvwmAudVid “” Title
“” Nop
  • “K3b” Exec exec k3b
    • “Vidz” Popup MenuFvwmVid
    • “Noize” Popup MenuFvwmAud
      DestroyMenu MenuFvwmVid
      AddToMenu MenuFvwmVid “Vidz” Title
  • “%$[fvwm_img]/mini/video.xpm% Gmplayer” Exec exec gmplayer
  • “%$[fvwm_img]/mini/xine.xpm% Xine” Exec exec xine
  • “%$[fvwm_icon]/hicolor/16x16/apps/dragonplayer.png% Dragon Player”
    Exec exec dragon
  • “” Nop
    AddToMenu MenuFvwmAud “Noize” Title
  • “%$[fvwm_icon]/nuvola/16x16/apps/amarok.png% Amarok” Exec exec amarok
  • “%$[fvwm_img]/png/16x16/apps/audacious.png% Audacious” Exec exec audacious
  • “%$[fvwm_icon]/nuvola/16x16/apps/juk.png% Juk” Exec exec juk
  • “%$[fvwm_icon]/hicolor/16x16/apps/kaudiocreator.png% KAudioCreator” Exec exec kaudiocreator
  • “%$[fvwm_icon]/hicolor/16x16/apps/kplayer.png% CD Player” Exec exec kplayer
Dev Menu
DestroyMenu MenuFvwmDev
AddToMenu MenuFvwmDev “” Title
  • “” Nop
  • “%$[fvwm_img]/png/22x22/apps/python2.5.png% Python IDE” Exec exec idle
  • “%$[fvwm_icon]/hicolor/22x22/apps/kapptemplate.png% KAppTemplate”
    Exec exec kapptemplate
  • “%$[fvwm_icon]/hicolor/22x22/apps/kompare.png% Kompare”
    Exec exec kompare
  • “%$[fvwm_icon]/hicolor/22x22/apps/kturtle.png% KTurtle”
    Exec exec kturtle
  • “%$[fvwm_img]/png/22x22/apps/python2.5.png% Term Python”
    Exec exec xterm -r -e python
  • “%$[fvwm_img]/png/22x22/apps/gdb.png% Term gdb”
    Exec exec xterm -r -e gdb
Games Menu
DestroyMenu MenuFvwmGames
AddToMenu MenuFvwmGames “<Insert .25>” Title
+ “B/W” Popup MenuFvwmBW
+ “Color” Popup MenuFvwmColor
DestroyMenu MenuFvwmBW
AddToMenu MenuFvwmBW
+ “Gomoku” Exec exec xterm -e gomoku
+ “Hangman” Exec exec xterm -r -e hangman
+ “Hunt” Exec exec xterm -r -e hunt
+ “Snake” Exec exec xterm -r -e snake
DestroyMenu MenuFvwmColor
AddToMenu MenuFvwmColor
+ “%$[fvwm_img]/png/16x16/apps/dosbox.png% DosBox” Exec exec dosbox
+ “%$[fvwm_icon]/hicolor/16x16/apps/kolf.png% Kolf” Exec exec kolf %U
+ “%$[fvwm_icon]/hicolor/16x16/apps/ksirk.png% KsirK” Exec exec ksirk
Help Menu
DestroyMenu Help
AddToMenu Help “<911>” Title
“” Nop
  • “%/usr/include/X11/pixmaps/mini.xman.xpm% ManPages” Exec exec xman
  • “KHelp Center” Exec exec khelpcenter
  • “Info” Exec exec xterm -geometry 130x50 -r -e info
Office Menu
DestroyMenu MenuFvwmOffice
AddToMenu MenuFvwmOffice “” Title
“” Nop
  • “BrainDump” Exec exec “braindump”
  • “Calendar” Exec exec “orage”
    • “Calligra” Popup MenuCalli
      DestroyMenu MenuCalli
      AddToMenu MenuCalli “” Title
      • “Flow” Exec exec calligraflow
      • “Mobile” Exec exec calligramobile
      • “Sheets” Exec exec calligrasheets
      • “Stage” Exec exec calligrastage
      • “Words” Exec exec calligrawords
Programs Menu
DestroyMenu MenuFvwmPrograms
AddToMenu MenuFvwmPrograms “” Title
“” Nop
+ “Terms” Popup MenuTerms
+ “Scribbly” Popup MenuScrib
+ “EduPlay” Popup MenuEdu
+ “Coloring Book” Popup MenuCbook
DestroyMenu MenuTerms
AddToMenu MenuTerms
+ “XTerm” Exec exec xterm -r
+ “UXTerm” Exec exec uxterm -r
+ “Terminal” Exec exec terminal
DestroyMenu MenuScrib
AddToMenu MenuScrib
+ “%$[fvwm_icon]/oxygen/16x16/apps/ksnapshot.png% Snapshot”
Exec exec ksnapshot
+ “%$[fvwm_icon]/oxygen/16x16/apps/karbon.png% Karbon”
Exec exec karbon
+ “%$[fvwm_icon]/hicolor/16x16/apps/gwenview.png% Gwenview”
Exec exec gwenview
+ “%$[fvwm_icon]/oxygen/16x16/apps/krita.png% Krita”
Exec exec krita
DestroyMenu MenuEdu
AddToMenu MenuEdu
+ “%$[fvwm_img]/png/16x16/apps/kstars.png% Kstars”
Exec exec kstars
+ “%$[fvwm_img]/png/16x16/apps/kiten.png% Kiten”
Exec exec kiten
DestroyMenu MenuCbook
Addtomenu MenuCbook
+ “%$[fvwm_img]/mini/xv.xpm% XV” Exec exec xv
Tools Menu
DestroyMenu MenuFvwmTools
AddToMenu MenuFvwmTools “” Title
“” Nop
  • “XFontSel” Exec exec xfontsel
  • “AppFinder” Exec exec xfce4-appfinder
  • “Find it” Exec exec kfind
  • “Ark” Exec exec ark
Utilities Menu
leaving some in just in case
The Circulate is a little confusing but here is a good place to explain
it:http://www.fvwm.org/doc/unstable/fvwm/fvwm.man.html#conditions
DestroyMenu MenuFvwmUtilities
AddToMenu MenuFvwmUtilities “” Title
+“IconBox” Funckage.box
  • “WinOps” PopUp WindowOpsMenu
    DestroyMenu WindowOpsMenu
    AddToMenu WindowOpsMenu “Window Operations” Title
  • “Identify %$[fvwm_img]/mini/mini.question.xpm%” Module FvwmIdent
    #+ “Move %$[fvwm_img]/mini/mini.move1.xpm%” Move
    #+ “Resize %$[fvwm_img]/mini/mini.resize3.xpm%” Resize
  • “(De)Iconify %$[fvwm_img]/mini/mini.iconify.xpm%” Iconify
    #+ “(Un)Maximiz %$[fvwm_img]/mini/mini.winXX-maximize.xpm%” Maximize
    #+ “(Un)Shade %$[fvwm_img]/mini/mini.shade1.xpm%” WindowShade
  • “(Un)Stick %$[fvwm_img]/mini/mini.stick1.xpm%” Stick
  • “” Nop
  • “Close %$[fvwm_img]/mini/mini.winXX-close.xpm%” Close
  • “Delete %$[fvwm_img]/mini/mini.delete.xpm%” Delete
  • “Destroy %$[fvwm_img]/mini/mini.destroy.xpm%” Destroy
  • “” Nop
  • “Top %$[fvwm_img]/mini/mini.raise.xpm%”
    Pick (CirculateHit) Layer 0 6
  • “Layer +1 %$[fvwm_img]/mini/mini.raise3.xpm%”
    Pick (CirculateHit) Layer +1
  • “StaysPut %$[fvwm_img]/mini/mini.window2.xpm%”
    Pick (CirculateHit) Layer 0 4
  • “Layer -1 %$[fvwm_img]/mini/mini.lower.xpm%”
    Pick (CirculateHit) Layer -1
  • “Bottom %$[fvwm_img]/mini/mini.lower3.xpm%”
    Pick (CirculateHit) Layer 0 2
  • “” Nop
    • “Move It” PopUp WinMoveMenu
      DestroyMenu WinMoveMenu
      AddToMenu WinMoveMenu “Move it!” Title
      #moves the app to another page - function is in kage.func
  • “Move R” FuncMoveWindowToPage +1p +0p
  • “Move L” FuncMoveWindowToPage -1p +0p
  • “Move U” FuncMoveWindowToPage +0p -1p
  • “Move D” FuncMoveWindowToPage +0p +1p
    #moves the window to the next/previous desktop and cycles back around
    #movetodesk is build-in function
  • “Move +1” MoveToDesk +1 0 2
  • “Move -1” MoveToDesk -1 0 2
    #[TODO]
    #+ “$[fvwm_img]/mini.picture.xpm Window Screenshot” Pick (CirculateHit) FvwmWindowScreenshot
    #+ “$[fvwm_img]/mini.display.xpm Screenshot” FvwmDesktopScreenshot 5
Web Menu
DestroyMenu MenuFvwmWeb
AddToMenu MenuFvwmWeb “” Title
#+ “” Nop
DestroyMenu MenuFvwmQuitVerify
AddToMenu MenuFvwmQuitVerify “[Really Quit Fvwm?]” Title
  • “%$[fvwm_img]/png/16x16/actions/application-exit-2.png%
    [Yes, Really Quit]” Quit
  • “” Nop
  • “%$[fvwm_img]/mini/restart.xpm%[Restart]” Restart
  • “” Nop
  • “%$[fvwm_img]/mini/terminal.xpm%[Just an Xterm]”
    Restart xterm -n ‘“X Console”’ -T ‘“X Console”’
  • “” Nop
  • “%$[fvwm_img]/png/16x16/actions/system-lock-screen-2.png% [Lock it up!]”
  • “No, Don’t Quit” Nop
Volume Control
DestroyMenu Volume
AddtoMenu Volume “” Title
“” Nop
  • " MUTE" Exec amixer -q sset Master toggle
  • " 10%%" Exec amixer sset ‘Master’ 3
  • " 16%%" Exec amixer sset ‘Master’ 5
  • " 23%%" Exec amixer sset ‘Master’ 7
  • " 29%%" Exec amixer sset ‘Master’ 9
  • " 35%%" Exec amixer sset ‘Master’ 11
  • " 42%%" Exec amixer sset ‘Master’ 13
  • " 48%%" Exec amixer sset ‘Master’ 15
  • " 55%%" Exec amixer sset ‘Master’ 17
  • " 61%%" Exec amixer sset ‘Master’ 19
  • " 68%%" Exec amixer sset ‘Master’ 21
  • " 74%%" Exec amixer sset ‘Master’ 23
  • " 81%%" Exec amixer sset ‘Master’ 25
  • " 87%%" Exec amixer sset ‘Master’ 27
  • " 94%%" Exec amixer sset ‘Master’ 29
  • “100%%” Exec amixer sset ‘Master’ 31
___ _
/ __\ _ _ __ __| | ___
/ | | | | ’ \ / __| __/ __|
#/ / | || | | | | (__| |__
#/ _,|| ||_|_|/
read kage.func
<kage.functs>
Window Buttons and Window ID
#| Root Window |
#| Icon |
#| F---------------frame side---------------------------F |
#| | 1 3 5 7 9 Title Bar 0 8 6 4 2 | |
#| |< frame sides | |
#| | V | |
#| F----------------------------------------------------F |
Contexts:
R = Root Window
W = Application Window
F = Frame Corners
S = Frame Sides
T = Title Bar
I = Icon
Mouse:
I = Immediate
M = Motion
C = Click
H = Hold
D = 2x click
Startup
AddToFunc StartFunction
  • I Module FvwmAnimate
  • I Module FvwmBanner
  • I Module FvwmButtons
  • I Module FvwmBacker
  • I Module FvwmIconBox
creates a debug window ‘just in case’ + I Module FvwmDebug -xc
Basic
This one moves and then raises the window if you drag the mouse,
only raises the window if you click, and drops or raises the
windowshade if you double-click.
AddtoFunc “Maximize”
  • “D” Maximize 100 100
AddToFunc “Move-or-Raise”
  • “M” Move
  • “M” Raise
  • “C” Raise
+ “D” Maximize 100 100"
  • “D” Windowshade
This one moves and then lowers the window if you drag the mouse,
only lowers the window if you click, or does a RaiseLower if you
double click
AddToFunc “Move-or-Lower”
  • “M” Move
  • “M” Lower
  • “C” Lower
  • “D” RaiseLower
This one moves or (de)iconifies:
AddToFunc “Move-or-Iconify”
  • “M” Move
  • “D” Iconify
This one resizes and then raises the window if you drag the mouse,
only raises the window if you click, or does a RaiseLower if you
double click
AddToFunc “Resize-or-Raise”
  • “M” Resize
  • “M” Raise
  • “C” Raise
  • “D” RaiseLower
You can probably guess what this does.
AddToFunc “Raise-and-FlipFocus”
  • “I” Raise
  • “I” FlipFocus
Move active window to next/previous page
DestroyFunc FuncMoveWindowToPage
AddToFunc FuncMoveWindowToPage
  • I MoveToPage $0 $1
  • I GotoPage $0 $1
Program Launch
This checks for firefox and then launches it from the kage.menu
website menu options
DestroyFunc FuncOpenURL
AddToFunc FuncOpenURL
  • I Test (x $[infostore.default_browser]) Exec $[infostore.default_browser] ‘$0’
  • I TestRc (!Match) Test (x firefox) Exec firefox ‘$0’
This start xscreensaver
DestroyFunc InitFunction
AddToFunc InitFunction
  • I Exec exec xscreensaver -no-splash
_____ ___
_ ___ ___ _ __ / __\ _____ __
/ // / _ | ’ \ /_/// _ \ / /
#_/ __/|| |____/__//_\
read kage.box
DestroyModuleConfig FvwmIconBox: *
Note that icons are shown in the module
ONLY if NoIcon commnand is applied.
#Style “*” NoIcon
Style "" NoIcon
FvwmIconBox: IconBack #1fdb22
FvwmIconBox: IconHiFore black
FvwmIconBox: IconHiBack LightSkyBlue
FvwmIconBox: Fore green4
FvwmIconBox: Back red4
FvwmIconBox: Geometry 6x1+0+1092
FvwmIconBox: MaxIconSize 32x32
FvwmIconBox: Font --clean-bold-
-normal-
-10-
*FvwmIconBox: SortIcons WindowName
*FvwmIconBox: Padding 1
*FvwmIconBox: Lines 10
*FvwmIconBox: SBWidth 11
*FvwmIconBox: Placement Left Top
*FvwmIconBox: Pixmap fvwm.xpm
#*FvwmIconBox: HideSC Horizontal
*FvwmIconBox: HideSC Vertical
*FvwmIconBox: SetWMIconSize
*FvwmIconBox: HilightFocusWin
*FvwmIconBox: Resolution Desk
*FvwmIconBox: Mouse 1 Click RaiseLower
*FvwmIconBox: Mouse 1 DoubleClick Iconify
*FvwmIconBox: Mouse 2 Click Iconify -1, Focus
*FvwmIconBox: Mouse 3 Click Module FvwmIdent
*FvwmIconBox: Key r RaiseLower
*FvwmIconBox: Key space Iconify
*FvwmIconBox: Key d Close
*FvwmIconBox: Key n Next
*FvwmIconBox: Key p Prev
*FvwmIconBox: Key h Left
*FvwmIconBox: Key j Down
*FvwmIconBox: Key k Up
*FvwmIconBox: Key l Right
Icon file specifications
Mostly, you don’t have to specify icon files, as FvwmIconBox now
reads icon files specified in Style commands.
#FvwmIconBox: "Fvwm" -
___ _ _ _
/ __() __ __| () __ __ _
/__// | '_ \ / _ | | '_ \ / _ |
#_/|| ||_,||| ||__, |
|___/
read kage.bind
#| Root Window |
#| Icon |
#| | V | |
Contexts:
R = Root Window
F = Frame Corners
S = Frame Sides
T = Title Bar
I = Icon
Mouse:
I = Immediate
M = Motion
C = Click
H = Hold
D = 2x click
Logitech M570 Mouse button format
|8| | | | u 4 |
|9| 1 | 3 | 2 | d 5 |
Mouse 1 R A Menu MenuFvwmRoot Nop
Mouse 2 R A Menu WindowOpsMenu Nop
Mouse 3 R A WindowList
#Scrollwheel to go up/down windows
Mouse 4 R A GotoPage +0p -1p
Mouse 5 R A GotoPage +0p +1p
#Scrollwheel to go left/right windows
Mouse 4 R S GotoPage +1p -0p
Mouse 5 R S GotoPage -1p +0p
#Buttons move to next desktop
goes to next desktop with 0 being first window
2 being the last window - it wraps around both
ways. Silent turns off max buttons and complex
function warning
Silent Mouse 8 R A GotoDesk +1 0 2
Silent Mouse 9 R A GotoDesk -1 0 2
for the title bar buttons:
Mouse 0 1 A Menu WindowOpsMenu Close
Mouse 0 2 A Close
Mouse 0 3 A Iconify
Mouse 0 4 A Maximize
for other parts of the window/borders/icons:
Mouse 1 F A Resize-or-Raise
Mouse 1 TS A Move-or-Raise
Mouse 1 I A Move-or-Iconify
Mouse 2 I A Iconify
Mouse 2 FST A Menu WindowOpsMenu Nop
Mouse 3 TSIF A RaiseLower
Keyboard:
Modifiers: (A)ny, ©ontrol, (S)hift, (M)eta, (N)othing
Key Next A SCM Next [] Focus
Key Prior A SCM Prev [
] Focus
Use Shift+Ctrl+number to go to different desktops
[TODO]
___ _ _
/ __\ __ _ ___| | ____ _ _ __ ___ _ _ _ __ __| |
//// _ |/ __| |/ / _ | '/ _ | | | | '_ \ / _` |
#/ / \ (| | (__| < (| | | | () | || | | | | (| |
#_
/_,|___||__, || ___/ _,|| ||_,|
|___/
read kage.backer
#####This is for the backgrounds of each of the Destkops
can be rgb.txt color, png-using fvwm-root, ColorSet
which is setup in fvwmtheme
DestroyModuleConfig FvwmBacker: *
The one below is for Home Desk(Desk 0)
#| 0 0 | 1 0 |
#| 0 1 | 1 1 |
#This sets the same thing for every page on Desk 0
*FvwmBacker: Command (Desk 0) Exec xv -max -root -quit $[fvwm_wall]/Pale_Blue_Dot.jpg
#The one below is for Whirk Desk (Desk 1)
#Gradient will only work if they are set in a Colorset
*FvwmBacker: Command (Desk 1, Page 0 0) -solid black
*FvwmBacker: Command (Desk 1, Page 1 0) Colorset 9
*FvwmBacker: Command (Desk 1, Page 0 1) Colorset 10
*FvwmBacker: Command (Desk 1, Page 1 1) Exec xv -max -root -quit $[fvwm_wall]/Kitty.jpg
The one below is for Desk 2
#For 2 of 4 windows of Serphin (Desk 2)
*FvwmBacker: Command (Desk 2, Page 0 *) Exec fvwm-root $[fvwm_img]/background/stone.png
*FvwmBacker: Command (Desk 2, Page 1 0) Exec xv -max -root -quit $[fvwm_wall]/Nina.jpg
*FvwmBacker: Command (Desk 2, Page 1 1) Exec xv -max -root -quit $[fvwm_wall]/s38g.jpg
