ok i’ very new to, well everything basicly, i have installed and can “startx”, i can access my university unix by ssh.
teacher told me use fvwm2 as window manager. so all i did was change the startxwin.bat line “run twm” to “run fvwm2”. when i run startxwin.bat it opens X with white window, with my username, nothing else!
when i type fvwm2, it says another WM is allready running!.
you probably already have fvwm running. By defualt there isn’t mush configuration. try clicking on the background, and if that brings up a menu go to the configurations/screenshot forum, and try to get yourself a good .fvwm2rc file.
