chojin
1
blue: schart.tuts.nu/blue.jpg
green: schart.tuts.nu/green.jpg
grey: schart.tuts.nu/grey.jpg
milk: schart.tuts.nu/milk.jpg
4 decoration/colorthemes - 2 iconthemes with matching gtk-themes and pypanel-config.
I will split the configs later, it’s frustrating to edit at the moment, because each theme has its own config.
where to read about making the titlebar vertical?
chojin
3
In the manpage.
Looks like this:
Style aterm TitleAtLeft
There are much more options.
chojin
4
I will post the adress to the complete tarball in the next few days. It’s already up, but there are some minor things I’d like to correct.
lucky
5
Hello,
i would like to know the name of the font you use in your menu please. Thanks
Good job !
chojin
6
In the green/blue/grey-thing I use Hooge 05_54 and in the milky one it’s Ahnenberg Hand.
lucky
7
Can you tell me where i could find the Hooge 05_54 ? I don’t find it
chojin
8
I have edited and split my config…
Now you can change themes and iconthemes, I’m still working on making “fontthemes”, it worked only partial so I removed it for now.
On first loading, it could be, that the themes aren’t loaded, just go to the menu points and chose.
Fonts and gtk-themes are included as well as a conky config and some wallpapers.
Read the README, it tells what you’ll need.
I hope you like it.
schart.tuts.nu/fvwm-theme.2005-10-14.tar.gz
