i’m trying to build mac os x like windows… i mean “no border”! but i want handles to make windows resizable and i can’t make them transparent or translucent… how to?
thanks in advance!
You can’t have handles on a window without the border.
may i suggest 2 choices:
- you set the window borders > 0 ( HandleWidth 1 is not very large to catch
them ) and you set:
Mouse 1 F A resize
- or use this :
AddToFunc RaiseAndResize
+ I Raise
+ C Resize direction SE WarpToBorder
Mouse 3 T A RaiseAndResize
I’ve never tried to make the windows border transparent but i think this is just a colorset question.
Old, but:
Using Resize with the WarpToBorder or Direction may well be the “better” option.
I’ll use current resize with the mouse button 3…
now… can i have only one side border? right side for example
thanks!
No. You get all four sides, or nothing.
i’m working on transparency and i use the next code:[code]+ I Exec exec aterm
- I Exec exec transset-df -i $[w.id] .7[/code]but it says
/bin/sh: w.id: syntax error in expression (error token is ".id")
and don’t know why… i use that variable in other functions and it works… i tried to put it between “” or double the $$ but i’m rambling
You’re probably running that outside a window context.
from forchheimer.se/transset-df/[code]# select window by clicking (as transset)
select window by pointing
select by window name or id[/code]i have to use one of these when i start an application… any suggestion?
the command in the previous post perhaps is usefull if i click on a button of the window… right? … yes, this works!
You can’t use it in the same function that you start the application in. You will have to use FvwmEvent:
Module FvwmEvent
*FvwmEvent: add_window "Exec exec transset-df -i $[w.id] .7"
in this way it happens every time a window is added, not?
Yes. You can selectively ignore windows:
ThisWindow (!"some_name|some_other_name|....") Exec exec ...
ThisWindow ("aterm") Exec exec ...
if i need only aterm
Yes. You don’t even need the quotes.
Thomas.
