Is there any way to find out how man instances of a certent app are running. Im writing a script to number my Eterms so i can keep track of them in the ALT-Tab window.
c=`ps -a|grep -i eterm|wc|sed 's/^ *//'|sed 's/ .*$//'`
echo $c
Greetings, Mark
or even simpler:
c=`ps -a|grep Eterm|wc -l`
echo $c
ps -a shows all processes
grep Eterm extracts the lines with “Eterm”
wc -l counts these lines.
Mark
pgrep gv | wc -l
is another way. Note that in the case of:
… the use of ‘wc’ is useless – let grep do the counting for you:
c=`ps -a|grep -c Eterm`
Or then you could use
Style * IndexedWindowName
Thanks for the help guys. Works like a charm.
VoiDeR
