Interesting – I like the colours, although I find the use of transparency a bit too heavy for my liking. I noticed in the red screenshot that your FvwmButtons had an “extra” bit at the end – with FvwmPager and a clock which doesn’t appear in the other shots – is this a toggleable addition to the existing FvwmButtons bar?
Nice config(s)! I actually found these before this forum from your website.
I really, really, love the wallpaper of the red theme. Where have you found it? Or have you done it yourself? It seems as it has been made with illustrator or such, which makes me wonder how long did it take to finish it.
It’s because the person who wrote the config hasn’t made use of variable such as $[vp.x] $[vp.y] and whatnot. That’s fine, but if you don’t run at the same resolution, you run into the same problems. So you’ll just have to manually ajust the -geometry settings, I’m afraid.
They’re options supplied to a program and not a separate file. So look in the ~/.fvwm/config file and play about with it. Note that something similar has already been asked, here
It’s a lot of work to do, to configure it such that it works for other resolutions. Reverse-engineering such a thing is possible (search the forums, as it has been discussed before.), but only if it was designed with it in mind.
The easiest thing for you to do is to hack the geometry locations yourself.
Hehe yes I have used the last 2 hours to puzzle the buttons to match precisely 1400 pixels…but still some won’t fit even if I add them together and the result is 1400.
