Greetings! This is my first time using fvwm and I’m loving the raw power to configure my desktop. I’m trying to create a function to take a screenshot and notify the user. I am wondering if it’s possible to pass fvwm variables like the current window id $[w.id] to external scripts? Example I’m adding to the Window-Ops2 menu is
# Menu for top left hand ("close") button on windows
AddToMenu Window-Ops2
+ "Raise/Lower " RaiseLower
+ "Iconify " Iconify
+ "(Un)Stick " Stick
+ "" Nop
+ "Delete " Delete
+ "Close " Close
+ "Destroy " Destroy
+ "" Nop
+ "Take Screenshot " Exec exec $[FVWM_USERDIR]/.local/bin/savescreenshot $[w.id]
And if anyone is interested, here is the trivial bash script I cobbled together in an attempt to take the screenshot.
#!/bin/bash
#set -x
# use -root for window_id if not specified
if [ $# -ne 1 ]; then
argument="-root"
else
argument="-id $1"
fi
type xwd >/dev/null 2>&1 || { echo >&2 "This script requires xwd but it's not installed. Aborting."; exit 1; }
type magick >/dev/null 2>&1 || { echo >&2 "This script requires magick but it's not installed. Aborting."; exit 1; }
type zenity >/dev/null 2>&1 || { echo >&2 "This script requires zenity but it's not installed. Aborting."; exit 1; }
test -e ~/Pictures || mkdir -p ~/Pictures
file="$HOME/Pictures/$(date '+%Y%m%d_%H%M%S')_screenshot"
sleep .1
xwd $argument | magick xwd:- $file.png
zenity --info --text "Screenshot saved to $file.png"
