Pb compilation fvwm3-1.1.1
I have trouble to compile fvwm3-1.1.1: i get
fsm.c: In function ‘fsm_init’:
fsm.c:1051:9: error: implicit declaration of function ‘_IceTransNoListen’ [-Wimplicit-function-declaration] 1051 | _IceTransNoListen(“tcp”);
make[2]: *** [Makefile:591: fsm.o] Error 1
How can i correct that ?
Thank u
Best regards
Laurent
All is ok now … and i don’t know why …
Surely an update with Arch … pacman -Suy … and now it’s ok …
If the issue is with a distro’s package, such as arch here, you should report build/package issues to them.
Note, this was fixed, also this is a report from before 1.1.1 was released.
