Hello PEM,
Is it possible to get your svg related config? The bottomline is that I have some display problems with my config ( viewtopic.php?f=39&t=1102 ) on Xorg 7.2.
6thpink has tested it and he has the same issue on Xorg 7.3. He thought it’s a problem with librsvg. But after recompiling it looks the same.
Therfore we need another svg config to check where the problem comes from. Perhaps it’s a problem in my config …
Could you help?
Best Regards,
TF
