Hi
wink @ mutze
I will post my config “when it’s done”, so far you can only look at a screenie - grab it here:
Screenshot
This config is intended to make working easy & fast, but still provide a little beauty(at least I think it does).
For the people who might think about using it(when I finished and uploaded it), be aware that their won’t be any ‘spiffy-I’m-looking-at-eyecandy-not-doing-my-work’ things
There is(and will be) only one menu, from witch you can edit the FVWM-config-files, but nothing to start applications from! Everything can and will be done by various shortcuts, may it be launching some apps or the window-handling, etc. pp.
The provided screenshot doesn’t show much, but I’ll explain it anyway
There’s nothing more than ‘irssi-svn’, ‘ncmpc’ and ‘mc’, each running in a (pseudo-)transparent ‘urxvt’.
The wallpaper is also nothing special - found the lil’ tux via google and made a minimalistic wp out of it(if someone wants it, there’re two versions on my gallery.
Comments are welcome, my config definetly will come in the next days!
cheers,
ph030
BTW:
Wanted to shout out a big thx to: TavisO, chwombat, ikaro, tBD, ThomasAdam, Nick Fortune and some others, who are always inspiring me and are doing a great work for the community
EDIT:
Spelling, inserted URLs
