I installed Fvwm-themes.
The themes are very modularized.
To change, copy the folder with a theme you like, e.g. from
/usr/share/fvwm/themes/blackbox to
/usr/share/fvwm/themes/test
Now you can change the files in /test , and immedeatly see if your changes work, by reloading the theme in the themes-menue.
If you do not want to work with fvwm-themes,
take a look at
clan-hash.com/~guli/fvwm/
You can download his configuration 1.5, it is very modularized, take it as a “base” and apply the changes you need.
Greets, Mark
