Hello again,
I have a small problem with the fvwm menus.
I never used titled menus before, so it is surely something that I am missing, but it has bothered me for a few days and I can’t seem to find a way to “solve” this.
I have the PopupImmediately and PopdownImmediately MenuStyle options turned on, so, when I hover a menu entry xxxx whose action is Popup, it automatically pops without any delay. It the xxxx submenu does not have a title, this works ok. But if I define a title on that submenu with something like “AddToMenu xxxx XXXX Title”, when the submenu is displayed the mouse pointer automatically jumps to the first entry on the submenu (with “first entry” I mean the first menu item, not the submenu title). If this entry is a Popup submenu itself, it is also open instantly, which is very annoying, overall in slow submenus which are generated dynamically.
I know I could just define a delay but I wonder if I am missing something here. I would like the submenu to open instantly, but I don’t like my pointer warping into it automatically. I have tried !TitleWarp but as I expected that option did not help.
Anything obvious that I am missing? I have tried commenting out all the MenuStyle entries on my config and it does not help either. I have tried several other things and searched around, but haven’t found a solution yet.
Thanks in advance for any help.
Regards.
