I am new to FVWM, but have it working pretty much as I would like. I do have a number of questions/problems, though, which I am trying to google/deal with one at a time.
However, I can not find out how to make the mouse NOT go to a pop up menu (when it pops up from a key press).
I also couldn’t search on the forums because both “menu” and “focus” were too common as search terms (the search rejected them)
How do you stop the mouse from going to popup menus ?
Search in your config(s) for “SelectInPlace”, “SelectWarp” or “TitleWarp”. If you find one remove it (“SelectInPlace”, “SelectWarp”) or disable it (“TitleWarp” with “!TitleWarp”).
For more information about menus see Menu and MenuStyle.
all the other settings work, but the pointer still goes to the menu when and where ever it appears, and, thus, also causes the first sub-menu to pop up.
When you - I mean anyone reading this - pop up a menu from a key stroke, do(es) your pointer(s) always go to the menu?
I actually replied a couple of days ago but that post has disappeared
I said, (1) “good reply” and (2) "unfortunately it is possible and is happening and is it possibly related to some ‘new windows get focus’ or something? "
